For F**k sake!!!!!!
retrofly
PostPosted: 18:39 - 25 Aug 2002    Post subject: For F**k sake!!!!!! Reply with quote
dam bollocks fuck, my bike sounds like this.......
Rattle..Rattle....squieesh.....sizure....squieeeeesh...sizure...rattle......rattle....
Bollocks
any ideas guys what might be up "cough, piston, splutter cough"
im well pissed off as i got replacement Rings, piston, and a new bore , 5 weeks ago!!!!!!! any ideas of what to do now Sad
Luke
"The food was not undelicious"
-Homer Simpson (Exceptional beast : Underachiving Human)
www.geocities.com/retrofly
Ropehead
PostPosted: 20:32 - 25 Aug 2002    Post subject: Reply with quote
Souns like it might of nipped up and kept running..
have u been running it in properly??
retrofly
PostPosted: 23:13 - 25 Aug 2002    Post subject: Reply with quote
hi
it still goes but there a high pitch scraping noise comming from the piston, before the "mini" siezure something inside the engine was rattleling lika a bitch, any ideas on what that was..thanx ropehead
Luke
PostPosted: 00:02 - 26 Aug 2002    Post subject: Reply with quote
Could be a few things, but I suspect you are going to have to take off the top end and have a look. Had it nipped up before? Rattle is likely to be worn piston (possibly caused by a seizure), worn bore (unlikely on a plated barrel, especially as the bike was OK when you pulled it apart), worn little end bearing (possible) or snapped rings (also possible). If it is snapped rings then watch out as they can damage the bore, costing you loads more money
Wingchunal
PostPosted: 15:03 - 28 Aug 2002    Post subject: Reply with quote
When i havent rode my bike for a while i start of and it gets to about 6 thou revs and starts sounding weird and have to change up a gear and does the same it only does this for about a minute thou Confused Confused
Zimma
Wheelie Junkie
PostPosted: 17:23 - 28 Aug 2002    Post subject: ... Reply with quote
luke.. same thing happens to my nsr, altho no rattle, basically riding along, high pitched scraping sound, like metal twisting agains metal, back wheel locks, pull over, wait a few mins, it starts again... same thing over and over... hmmm now mine doesnt start Very Happy
-Zimma
retrofly
PostPosted: 19:45 - 29 Aug 2002    Post subject: Reply with quote
hi
yeah zim, it will still start but the scraping noise is still there, after i ran it it had a little siezure as i opened it up for the first time but it was fine again after that, that was about 3 weeks ago could that have caused the problem?
Luke
PostPosted: 20:32 - 29 Aug 2002    Post subject: Reply with quote
retrofly wrote:
hi
Quite likely. Not a pattern piston they used by any chance? On my old MBX I rarely got the pattern pistons to last long enough to run the bike in before the seized.
It is rare that an engine will survive being nipped up without loads of damage. Might run for a bit, but the problem will probably get worse.
The last post was made 23 years, 342 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 1.54 - MySQL Queries: 13 - Page Size: 58.78 Kb
