removing crankshaft
Im-a-Ridah
PostPosted: 19:17 - 31 Aug 2007    Post subject: removing crankshaft Reply with quote
I followed like it says in the manual to heat the area around where the bearings are then tap the crankshaft with a hammer, but it doesn't come out. I can't heat the bearings directly, because I cant get to them, any ideas?
It's an RS125 btw Smile
cagiva gezzer
PostPosted: 19:25 - 31 Aug 2007    Post subject: Reply with quote
Hit harder.
Im-a-Ridah
PostPosted: 19:37 - 31 Aug 2007    Post subject: Reply with quote
cagiva gezzer wrote:
Hit harder.
Yea, but I dont want to knock it out of alignment Thinking
Jamie S
PostPosted: 19:42 - 31 Aug 2007    Post subject: Reply with quote
How long did you heat it for and what did you use ? Because by the sounds of it you aint heated it up enough.
Im-a-Ridah
PostPosted: 19:56 - 31 Aug 2007    Post subject: Reply with quote
I had it on there for a few minutes of direct heat on the shaft, and tried blowing heat over the casing around the bearings are another time for a few minutes. It was so hot I couldn't touch he casings for more than a second or two, even on the other side of the engine. It's a propane brazing torch btw...
lukamon
PostPosted: 01:00 - 01 Sep 2007    Post subject: Reply with quote
duuuuuuuuuuuuuuuh direct on the shaft?
heating things up EXPANDS THEM silly, no wonder it wont come out Laughing try heating up the casings. oh, and if the piston wont come off the wrist pin, heat it up with said heat gun Thumbs Up
killa wrote: Im an ass man myself
The last post was made 18 years, 343 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.96 - MySQL Queries: 14 - Page Size: 47.15 Kb
