Aprilia help Clicking sound when trying to start??
Ransom
PostPosted: 17:02 - 02 Sep 2007    Post subject: Aprilia help Clicking sound when trying to start?? Reply with quote
we have just got the battery charged to full power and fitted
now when we try the starter on my Aprilia 1994 RS Extrema
there is a clicking from a little box just behind the radiator front week
i have trieed to add some pics for you to see the box i mean,
1994 Aprilia RS 125 Extrema
Status: Almost there, no spark on fire up
Electician friend looking at it.(fingers crossed)
iooi
PostPosted: 17:35 - 02 Sep 2007    Post subject: Reply with quote
Starter solenoid.
Does it not turn the engine over ? If not you need a new one.
Ransom
PostPosted: 20:16 - 02 Sep 2007    Post subject: Reply with quote
it clicks on the press of the starter
we found out that the battery is knacked so im replacing that tomorrow
konsoli
PostPosted: 23:25 - 02 Sep 2007    Post subject: Reply with quote
When he asks if it turns over, after the click, which is the starter motor engaging, I think. It's where you hear it try to fire up. So when your battery is flat, it turns over at a slower pace until eventually it's so slow there's no point.
Check the connections on your battery.
Try the electric start, try the kickstart with a slight twist of the throttle.
If this don't work, make another post.
Also, don't wire the battery connections up wrong or you will see a lot of sparks and may hear a pop. the Red wire is positive, black is negative.
EDIT: Just read your post: Hope it is the battery. Good luck Wink
PostPosted: 23:41 - 02 Sep 2007    Post subject: Reply with quote
It is the starter relay / starter solonoid.
All it does is provide power directly from the battery to the starter motor when you press the starter button. Small current through the button triggers the relay so the large current can flow to the starter (putting that current through the switchgear would give it a short life).
However sounds like the problem is just the battery.
SoulRider
PostPosted: 21:14 - 03 Sep 2007    Post subject: Reply with quote
I just had same problem on my Arilia RSVR 02, replaced battery no joy, appears the starter relay is burnt out and this is a common problem with Aprilia's. Ive got replacement yamaha relay for mine as its more robust and cheaper, arrives tomorrow so will let you know if it works.
Not sure if yam relay will work on yours though but have part number if you need it, fingers crssed its just the bat.
My Bike Pics
The last post was made 19 years, 50 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.7 - MySQL Queries: 14 - Page Size: 48.85 Kb
