| ttr |
 ttr Crazy Courier
 Posted: 20:28 - 24 Sep 2007 Post subject: Probably a really basic question but.. |
On my top yoke is a bolt I need to undo to fit my new headlamp, but it's a bit mangled, and the spanner wont grip it properly - I know it's the right size, as it worked for the other bolt.. But it just kinda slips round, instead of locking in and turning the bolt.
What does one do in this situation?
/n00b  ____________________ GS125-> NT400->VFR400->CRM250->Z750 + GS125->NTV650 rat + VMX1200->GSF600 + GPz550 |
| G |
 G The Voice of Reason
| ttr |
 ttr Crazy Courier
 Posted: 20:37 - 24 Sep 2007 Post subject: |
There are no nuts - the bolts screw through the yoke and into the forks.
What I'm using is not a six point socket, I'm not sure of the apt term for it though.
Basically it's one of these:
https://www.lakewoodconferences.com/direct/dbimage/50189268/Combination_Spanner.jpg
The ring type end, is what I'm using.
You'll have to forgive my ignorance, but... Wall drive? Molegrip? ____________________ GS125-> NT400->VFR400->CRM250->Z750 + GS125->NTV650 rat + VMX1200->GSF600 + GPz550 |
| deanoet |
 deanoet World Chat Champion
 Posted: 20:42 - 24 Sep 2007 Post subject: |
https://www.surplusandadventure.com/ishop/800/shopscr3213.html
molegrips
the harder you turn the tighter they grip ____________________ ---------------------------------------------------------------------------------------------------------------------------------------------
| G |
 Posted: 20:53 - 24 Sep 2007 Post subject: |
My bad, I didn't actually read your post properly .
Get a new bolt then, if it's a bolt .
What you've pictured is a 12 point spanner.
The ring end has '12' points. A 6 pointed one will be similar to the shape of the bolt you are turning so less likely to slip.
A wall drive socket is designed to grip the sides rather than the corners of the bolt, meaning that it's less likely to slip and round it off even more.
Machinemart does sets of wall-drive sockets quite cheaply. |
| ttr |
 ttr Crazy Courier
 Posted: 21:00 - 24 Sep 2007 Post subject: |
I think the bolt would need to be quite specific, looking at the other one. It has a rubber o-ring, and the shaft is wider than the head, and hollow, but it has a sort of domed lip between the shaft and the head.. Hard to describe, could get a pic if need be.
G, is this what you're referring to?
https://www.machinemart.co.uk/shop/product/details/pro152-18pce-38-drive-socket-set
I searched and this is what I came across.
The bolt's head is 17mm, by the way. ____________________ GS125-> NT400->VFR400->CRM250->Z750 + GS125->NTV650 rat + VMX1200->GSF600 + GPz550 |
| G |
 Posted: 21:11 - 24 Sep 2007 Post subject: |
Yep, something like that should be ideal.
I haven't used them myself, but I believe they are 6 point wall drive style.
Even if they don't do the job, it's a worthwhile addition to your tool kit . |
| ttr |
 ttr Crazy Courier
 Posted: 21:12 - 24 Sep 2007 Post subject: |
Righto!
Given that they're the same price, would you say I'm better off getting the wall drive sockets or the molegrips?  ____________________ GS125-> NT400->VFR400->CRM250->Z750 + GS125->NTV650 rat + VMX1200->GSF600 + GPz550 |
| G |
| TheShaggyDA |
 TheShaggyDA Repost Police
 Posted: 21:21 - 24 Sep 2007 Post subject: |
Wall drive sockets give you a better chance of reusing nuts and bolts afterwards, molegrips are extremely useful for other things too. Ideally, you'd want both in your tool kit. I'd say molegrips first, but it's close really. Toss a coin  ____________________ Current: CB500 Previous: CB100N, CB250RS, XJ900F, GT550, GPZ750R/1000RX, AJS M16, R100RT, Enfield Bullet
[i:6e3bfc7581]But still I fear and still I dare not laugh at the madman...[/i:6e3bfc7581] |
| Andyco11 |
 Andyco11 Borekit Bruiser
The last post was made 19 years ago. Instead of replying here, would creating a new thread be more useful? |
