| cagiva gezzer |
 cagiva gezzer World Chat Champion
 Posted: 13:25 - 28 Sep 2007 Post subject: Car MOT |
Just giving my friends Golf a once over before the MOT.
What i know
Tyre is slit, assuming it's a fail.
Rear brake binding, will fail if it binds again.
What i need advice on
How bouncy is bouncy when it comes to spotting failed dampers? I drive a car with sports suspension, so this golf feels like a bouncy castle. Is it just down to each mechanic?
If a car is fitted with a rear windscreen wiper, does it have to work? i.e. this one won't work.
 ____________________ "because one stroke isnt enough and four strokes waste two" |
| biglee |
 biglee Two Stroke Sniffer
| Drew |
 Drew Banned
| Nb |
 Nb World Chat Champion
 Posted: 18:22 - 28 Sep 2007 Post subject: |
Rear wiper isnt tested so dont worry about that (front wipers are tested for operation and their job of clearing the screen)
As for tyres...C.
| Quote: | Condition of Tyres
1. Examine each tyre for a. a tyre has a cut the length of which is at least 25 mm or 10% of section width, whichever is greater, deep enough to reach the ply or cords
b. lumps, bulges, tears, exposure of the ply or cord, or tread separation
Note: On radial ply tyres, care should be taken to distinguish between normal undulations in the carcass, resulting from manufacturing, and lumps or bulges caused by structural deterioration b. a tyre has a lump, bulge or tear caused by separation or partial failure of its structure. This includes any lifting of the tread rubber
any of its ply or cord exposed |
As for shocks they have to be pretty darn bad to fail....
| Quote: | A shock absorber which has negligible damping effect. |
When you bounce it once how long does it continue to rise and fall?
Is their no way you can fix the binding brake? |
| cagiva gezzer |
 Posted: 18:52 - 28 Sep 2007 Post subject: |
Brake - wheel off, wiggle the calliper. Freed it up, but the rear side of the disc has only had 30% of the surface worn, the rest is rust. Near side of the disc is grooved.
Works now, but i didn't drive it.
Suspension. Just feels rather wobbly. Doubt its as bad as i make it out and kwickfit had just replaced the rear dampers (and didn't fit any boots), so i assume the checked the fronts.....
It gets a few oscillations, and coming to a heavy stop makes it wallow.
TBH, sod her, she picked it up and belted off, hardly noticing that i'd taken dents out and polished out the reds / blues / blacks from the silver paintwork from where she'd rubbed things.
Was also off the bottom of the dipstick for engine oil. - VW TDI1.9 . . . . . . ..  ____________________ "because one stroke isnt enough and four strokes waste two" |
The last post was made 18 years, 327 days ago. Instead of replying here, would creating a new thread be more useful? |
