R1 Help!!
EllioTT_GiXXeR
PostPosted: 00:44 - 20 Oct 2007    Post subject: R1 Help!! Reply with quote
Today my R1 just lost power when i was riding along, i came to a stop and it just died, didn't hear a bang or anything.
It will JUST about start with the choke on and as soon as you give it any throttle it will die.
So i had to push the bike home and i got a flat tyre on my scooter also this week! Not going too well.
Any help would be greatfull. Thumbs Up Thumbs Up Thumbs Up Thumbs Up
www.gixerjunkies.net www.gixerjunkies.net www.gixerjunkies.net www.gixerjunkies.net
Paddy Blake
PostPosted: 01:03 - 20 Oct 2007    Post subject: Reply with quote
It sounds like it is just not getting fuel or water in the carbs.See if you can
drain the carbs using the drain screw on the bowls of each carbs.
Check what the fuel looks like when you drain it to see if there is dirt or
water.
Paddy.
tonyyzf
PostPosted: 09:00 - 20 Oct 2007    Post subject: Reply with quote
sounds like it ran out of petrol, check your fuel pump is working, you should hear it when you turn the ignition on
Something dark reddish with two wheels and cagiva written on the side
SS50, CB175, CB250N, CB350, CB750K2, DT250, CB750K1, CB750F1, XS1100, CB750F2, FJ1200, FZR1000, YZF1000, GSXR1000, Cagiva Navigator, Triumph Tiger 1050
https://www.cliqueyclanmcc.co.uk/
EllioTT_GiXXeR
PostPosted: 13:03 - 20 Oct 2007    Post subject: Reply with quote
Seems to be working fine this morning, mybe there was some crap in the line or something, ive only had the bike 2 days and its been standing a while.
Think the carb needs a clean
TUG
PostPosted: 13:05 - 20 Oct 2007    Post subject: Reply with quote
blocked jet i'd say, sounds like what happend to me, just happend all of a sudden, was a ball of silicone. castard to get out, it blocked both jets in my 4th carb the gay lol.
Haz ER-5, innit!
bish777
PostPosted: 14:53 - 20 Oct 2007    Post subject: Reply with quote
1) Have you run out of fuel?
2) Check the operation of the fuel tap (if you have a carbed R1). Try putting it on PRIME and see if the bike runs. Put it on prime, then open the drain screw on one of the float bowls, fuel should spill out. If very little dribbles out then stops, you either have a problem relating to the fuel tap or you have run out of fuel. MAke sure the ignition is on so the fuel pump operates.
3) Try removing the fuel cap, listen for a HISS as you remove it, perhaps your fuel cap breather is blocked.
GSXR1100J
EllioTT_GiXXeR
PostPosted: 23:26 - 20 Oct 2007    Post subject: Reply with quote
Loads of petrol in it, seems to be working ok at the moment, not sure if its worth getting it checked over since am gonna be using it every day.
Paddy Blake
PostPosted: 00:08 - 21 Oct 2007    Post subject: Reply with quote
Some times it can seem ok around town and have water in the bottom
the carb bowls that will effect it when you go for a long ride and are using
more fuel.
Just drain the carbs to be sure as it is not a big job and can save you from
being stuck in the middle of no where.
Paddy.
TUG
PostPosted: 02:19 - 21 Oct 2007    Post subject: Reply with quote
gotta agree with paddy and just hold the jets upto the light to check for a block, worth a look.
take them out one by one though so you cant mix em up.
Haz ER-5, innit!
EllioTT_GiXXeR
PostPosted: 19:23 - 21 Oct 2007    Post subject: Reply with quote
Ok it cut out again before, just waiting for the breakdown truck to get back to my house, oh joy!
So i got three bikes and can't use none of them for work, so i wont bother going in tomorrow.
TUG
PostPosted: 19:42 - 21 Oct 2007    Post subject: Reply with quote
carbs off mate, check your airfilter too, and the fuel line filters, theres a little one in the pipe conecting to the carbs like a little reed one.
take of the float bowls and check the floats and all the internels, check the jets too by unscrewing them and holdin them upto a light, take them out 1 by one so you cant mix them up.
if you run into more trouble give us lot a shout Thumbs Up
Haz ER-5, innit!
EllioTT_GiXXeR
PostPosted: 23:56 - 04 Nov 2007    Post subject: Reply with quote
MY freind took it apart today, he said he can't see nothing wrong. He can only think of a electric problem mybe?
I mean it cut out the other and that was 5mins into the trip.
He cleaned everything out though but said he couldn't see any problems.
Not gonna use it for work just incase.
Finglonga
PostPosted: 13:28 - 05 Nov 2007    Post subject: Reply with quote
Did you open the fuel cap then try to start it?
Andy Sez....
F.Y.Y.F.F.
the grim reaper
PostPosted: 14:16 - 05 Nov 2007    Post subject: Reply with quote
It definitely sounds like a fuel starvation problem, hence it will run on choke but dies as soon as you ask for some more petrol.
Could be any number of things though but I am also wondering about a blocked fuel breather. That takes a while to pressurise the tank enough to stop fuel flow.
Grim
bish777
PostPosted: 01:50 - 07 Nov 2007    Post subject: Reply with quote
Its probably either the vacuum hose to the fuel tap , the tap itself(WHAT YEAR IS YOUR R1??)
or the fuel cap breather.
Your friend cant say what the problem is unless he dismantled the fuel tap, and the filler cap.
GSXR1100J
EllioTT_GiXXeR
PostPosted: 12:55 - 08 Nov 2007    Post subject: Reply with quote
Its a 99 R1, i am gonna use it back to work on friday and if it cuts out then i will say fuck it and part ex it for a new one on saturday, can't carry on using a stupid scooter.
Finglonga
PostPosted: 14:19 - 08 Nov 2007    Post subject: Reply with quote
HAVE YOU OPENED THE FUEL FILLER CAP WHEN IT CUTS OUT THEN TRY ED TO START IT TO SEE IF ITS THAT?
That is the first thing to check, you have not said what you have tried yet and you have given up and decided to throw money away.
Andy Sez....
F.Y.Y.F.F.
The last post was made 18 years, 344 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.03 - MySQL Queries: 13 - Page Size: 95.07 Kb
