Dt leaking coolant?
Tom_N
PostPosted: 20:27 - 02 Nov 2007    Post subject: Dt leaking coolant? Reply with quote
Hello, Basically was out on the dt and parked it. Half an hour later i returned to see a yellow substance on the floor which i believe to be coolant. It isnt oil because there is no body to it. It was only a really small amount just below where there are several overflow pipes at the swing arm. I took off the oil cap and seen the same colour of substance in the gearbox? Doesnt sound great? Its an 06 bike. Am i worrying over nothing?
Tam
hmmmnz
PostPosted: 21:51 - 02 Nov 2007    Post subject: Reply with quote
drain your oil and see if it has water in it,
does the filler cap have some white muck on it??
(from oil and water mixing)
how the water would get into the gear box of a 2 stroke is beyond me,
i would have said it was almost impossible,
i d say you have nothing to worry about,
but it is worth doing a oil change before winter any way Very Happy
may as well do a radiator fl;ush and change the coolant while your at it Very Happy
the humans are dead
I kick arse for the lord
bugsy46
Village Idiot
PostPosted: 21:57 - 02 Nov 2007    Post subject: Reply with quote
Coolant overflow pipe maybe!!!???!!!???? Laughing
Laura - "And where did looks come into this and bugsy leave steven alone. You are not gods gift to women you may think you are but you're not."
Keith - "All the best"
garyd
PostPosted: 09:43 - 03 Nov 2007    Post subject: Reply with quote
I was out the other night ,bursting for a piss ,saw this DT and ...................sorry ,did you taste it ? Very Happy
finpos
PostPosted: 11:55 - 03 Nov 2007    Post subject: Reply with quote
hmmmnz wrote:
how the water would get into the gear box of a 2 stroke is beyond me, i would have said it was almost impossible
... busted water pump seals, but then there's usually drain between the water and oil seals to stop that happening. So unlikely but not impossible.
However, very unlikely indeed on a newish bike. Sounds more like the coolant boiled over after you stopped the engine and chucked a bit out of the overflow/breather. Check the coolant levels in both the radiator and the expansion bottle (when the engine is cold). Coolant is slippery but thin, and has a peculiar smell, you should be able to distinguish it from oil easily enough.
f.
The last post was made 18 years, 344 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 3.61 - MySQL Queries: 14 - Page Size: 44.84 Kb
