Sticking ignition barrel
tokarev
PostPosted: 20:53 - 25 Nov 2007    Post subject: Sticking ignition barrel Reply with quote
Hi!
When I put the key into the ignition barrel and try to turn the key from the "Lock" position to the "Off" position it seems to stick.
It takes a few tries to get it to turn. I don't want to snap my key! So is there anything I can do so that this does not happen?
Thank you.
mr jamez
PostPosted: 20:54 - 25 Nov 2007    Post subject: Reply with quote
Spray some WD40 in there, usualy sorts it.
tokarev
PostPosted: 20:56 - 25 Nov 2007    Post subject: Reply with quote
Wow, thanks for the quick answer!
Yeah, I was thinking about putting WD40 in there, but just wanted to make sure.
Thanks.
Jamie S
PostPosted: 20:59 - 25 Nov 2007    Post subject: Reply with quote
Wd40 is fine, you sure the key is not bent a little bit ?
tokarev
PostPosted: 21:06 - 25 Nov 2007    Post subject: Reply with quote
Nah, the key is fine. I only noticed it happening when I went to the bike after work last Thursday night at about 1am. I figured it was just the cold causing it to stick.
Cheers.
Phil_P
PostPosted: 09:23 - 26 Nov 2007    Post subject: Reply with quote
I'd use, some WD40 just to free everything up, then perhaps a squirt of something a bit heavier, perhaps with graphite or other slippery stuff to keep it slick. I use some spray bicycle oil, especially in my filler cap key, as that tends to lose all of it's lube.
It is not enough to win, others must fail.
Moto Guzzi 1100 Sport Injection '96
PostPosted: 11:02 - 26 Nov 2007    Post subject: Reply with quote
Chain lube ftw. Worked on my old knackered petrol cap. Cool
Richard_Schmid
PostPosted: 11:19 - 26 Nov 2007    Post subject: Reply with quote
With out being condesending, alot of the time you have to jiggle the handle bars slightly to undo the steering lock Rolling Eyes . I assume you are doing this? Wink
All the best,
Richard
tokarev
PostPosted: 11:57 - 26 Nov 2007    Post subject: Reply with quote
Cheers for the advice guys! I am going to put some WD40 in it later.
All the best,
Richard
Lol, yes of course. Been doing it for 3 years with no problems. Only started last week. Thumbs Up
Thanks.
veeeffarr
PostPosted: 12:10 - 26 Nov 2007    Post subject: Reply with quote
Have you tried with the spare key?
Ichy
PostPosted: 14:24 - 26 Nov 2007    Post subject: Reply with quote
Happens a fair bit this time of year, must be down to damp and cold.
I use grease or vaseline, stick it on the key and jiggle it around in the lock. Coats the internals and stops water getting in there. Also stops your locks freezing when it gets real cold. Just remember to clean your key afterwards.
konsoli
PostPosted: 19:04 - 26 Nov 2007    Post subject: Reply with quote
happens to me too, on spare key or original.
PostPosted: 19:36 - 26 Nov 2007    Post subject: Reply with quote
Probably gummed up with road flm.
Years ago I had a 100cc bike and in the winter the ignition-lock used to freeze up solid. I cured it by pouring a kettle of boiling water onver the lock, blowing it out with an air-line and squirting it full of WD40. Worked for the throttle cable too, which also froze one day whilst I was out riding.
The last post was made 18 years, 324 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.07 - MySQL Queries: 14 - Page Size: 75.48 Kb
