| Dischord |
 Dischord World Chat Champion
 Posted: 22:38 - 26 Nov 2007 Post subject: Halfords bike builder... |
got a 'test' there tomorrow but not sure what it's gonna involve.
I can put on handle bars, wheels, tyres, brakes etc but does anyone know if I'm gonna have to build up the crank and headstock as I'm a bit of a newb with that. ____________________ 2012 KTM EXC 250
Check out my vids - https://www.youtube.com/user/KTMSparky/videos |
| D O G |
 D O G World Chat Champion
 Posted: 23:20 - 26 Nov 2007 Post subject: |
I would doubt it TBH - I think your knowledge is quite sufficient - their bikes will almost certainly come in with the bottom bracket installed.
Building headstock is a piece of piss - just make sure;
1 - you get the bearings and carriers in the correct order
2 - you nip it all nicely together with the top bolt (i.e. the vertical one), but not too tight, as it is the headstem which goes on nice and tight and really prevents the forks dropping out. (clearly you will need the stem and any spacers on the fork tube first).
Other than that I think you'll be ok - though I don't know much about MTB stuff, I'm ok with proper bikes
Good luck |
| Ariel Badger |
 Ariel Badger Super Spammer
 Posted: 23:47 - 26 Nov 2007 Post subject: |
If it is the Halfords in Digbeth, Brum hands off the nice Asian chick on checkout.  ____________________ Bikers make great organ donors, get 115 on your licence today. |
| D O G |
| Ghost |
 Ghost Could Be A Chat Bot
| Dischord |
 Posted: 00:09 - 27 Nov 2007 Post subject: |
| Damofo D.O.G. wrote: | I would doubt it TBH - I think your knowledge is quite sufficient - their bikes will almost certainly come in with the bottom bracket installed.
Good luck |
Cheers for the info!
| Ghost wrote: | The bikes in Halfords come with the cranks, chainrings and bottom bracket already assembled, but pedals are either missing or you get two left hand ones and no right ones. Back wheel is normally already in but the gears will need setting up. Forks will already be in, but you'll need to put the handlebars and steerer in and tighten it up. Front wheel on, adjust front and back brakes and all the other things like saddle, seatpost, reflectors, bells, etc. Takes about half an hour to do one, maybe longer. |
You know what mate, that's spot-on! Can find anything out on BCF! I was hoping it would be simple like that thanks again!
EDIT - Two small things? by setting up the gears do you mean just putting the chain on and aligning it right between the front and rear sprcokets/chainrings? also what do you mean by steerer? Sorry just don't wanna get down there and be faced with something I can't solve as this job would come in handy over xmas now. ta! ____________________ 2012 KTM EXC 250
| cagiva gezzer |
 cagiva gezzer World Chat Champion
 Posted: 00:41 - 27 Nov 2007 Post subject: |
There's a difference between a bike builder and someone who PDIs them before they go out the door.
TBH, no one expects a bike from halfrauds to be built well anyway.
There's nothing you can't pick up on the job, but there's always neat tricks / tips that make the finished bike look / ride soo much better and lasts longer. ____________________ "because one stroke isnt enough and four strokes waste two" |
| EuropeanNC30R... |
 EuropeanNC30R... Gay Hairdresser
| UnknownStuntm... |
 UnknownStuntm... World Chat Champion
 Posted: 11:44 - 27 Nov 2007 Post subject: |
I was that soldier a few years ago. TBH as long as you can hold the right end of a hammer and know about how not to cross thread pedals when putting them on, you'll be fine.
It's worth bearing in mind that right NOW is the very busiest time of year for the bike boys in Halfords, they'll be getting hundreds of bikes delivered probably twice or three times a week to the shops, and a lot of time will be taken taking the stock in and arranging it so you can get to the bikes when you need them.
Lots of box shifting and probably some late nights.......
Then in January you can look forward to Mr and Mrs Bastard coming in with their son Antichrist who took a tumble while 'only going slowly' on his budget scaffold tube bike, over Ben fucking Nevis and broke every bone in his fatass too-tight-skinned body and how they want a refund and compensation. And the store manager will direct them to you and make a sharp exit.
Yeah good luck with that.  |
| Visitor Q |
 Visitor Q $25 whore
| Ghost |
 Posted: 23:36 - 27 Nov 2007 Post subject: |
Nah, by setting up the gears I mean just adjusting the rear and front mechs so they shift up and down smoothly. At least, that's the idea, it becomes harder than it sounds once you take into account the gear cables made from elastic, plastic levers that bend like beckham, barrel adjusters that snap, limit adjuster screws made of cheese and mech cages of tin that twist under any force at all. The chain will already be on and most of the time most brake and gear cables will already be attached, they'll just need routing and sorting properly.
Most Halfords bikes aren't sold with proper 'Aheadset' fittings i.e a steerer tube that's part of the forks, then a stem that bolts onto the top of the steerer and the handlebars. They're mostly the cheaper variant of steerer, stem and handlebars all being one piece of badly welded together junk. To assemble these you basically slacken off the allen key bolt on top of the steerer, slide the steerer down into the headtube of the frame, adjust it so it's pointing vaguely in the same direction as the front wheel and re-tighten the top allen key bolt. Make sure all your cables are routed the right way and voila, job done.
Hope this helps  |
| D O G |
| Cillit-BANG |
 Cillit-BANG World Chat Champion
| Teaman |
 Teaman World Chat Champion
 Posted: 21:03 - 28 Nov 2007 Post subject: |
| UnknownStuntman wrote: | I was that soldier a few years ago. TBH as long as you can hold the right end of a hammer and know about how not to cross thread pedals when putting them on, you'll be fine.
oh how right you are
spent years being the mechanic for a company in sheffield. and worked for orbit bikes.
build so many wheels it's impossible to remember, from 1 cross to radial to snowflake and never had one break.
bike building is a doddle, setting them up safe for the road is next but as long as you know the basics and have all the correct tools its easy.
The ammount of times I've gone out on boxing day and seeing kids who have had there bike for xmas that there dads put together with the forks facing the wrong way and reflectors dragging in the spokes.
remember with spanner attathed pedal backwards with both cranks to tighted the pedals, (One if left hand thread, THE ONE WITH THE NOTCHES) ____________________ There is no point in ranting about someone stupid because there is nothing u can do about it. There is no cure for stupid.
Someone stupid does not realise they r stupid.stupidity is indistinguishable from malice U just have to accept that some people are thick as p1gsh1t and work around them. |
| Dischord |
 Posted: 15:53 - 30 Nov 2007 Post subject: |
LOL cheers for all the replies! Got the job on wednesday and been working there since, to be fair it's quite an enjoyable job (not career material ) Just searching for the bikes, building them, listening to radio one, chatting and drinking coffee!
As stated it was pretty simple after all (thanks) but the assistant manager is so meticulous about how he likes the brakes and gears set up it becomes tedious working to his standards. ____________________ 2012 KTM EXC 250
| UnknownStuntm... |
 Posted: 16:17 - 30 Nov 2007 Post subject: |
Well just for your own peace of mind, listen to the man and pay very good attention to the brakes. Some of those shonky old RSJ tubed "bikes" have the brakes assembled but left loose (indonesian sweatshop muppetery I reckon) before they go in the box.
I remember having to tell everyone about a million times to check the brake pads were tight on the calipers... And like I said, Mr and Mrs Bastard will go to head office where someone from 'customer service' will tell them what a turd you were for not checking them....
But well done fella, good work. Oh, and just to make me smile, why not sneak a pic of the cycle warehouse in it's current state on here so that I may be smug?  |
| Dischord |
 Posted: 19:18 - 30 Nov 2007 Post subject: |
hehe I was thinking of taking a pic earlier but thought it would look dodgey, I'll get one for you on monday though!  ____________________ 2012 KTM EXC 250
| Teaman |
 Posted: 00:34 - 01 Dec 2007 Post subject: |
such is life, the leading edge of the brake to be touching and the back endge slightly less than a mil away from the rim will be perfect to stop brake squeel, the brakes flex on most bikes, this will give best braking performance , My standards are high aswell,
setting gears so there as smooth as silk was a pain in the arse at first but once you suss it you wouldn't have anything less mate. ____________________ There is no point in ranting about someone stupid because there is nothing u can do about it. There is no cure for stupid.
| UnknownStuntm... |
 Posted: 09:15 - 01 Dec 2007 Post subject: |
Oh yeah one more thing (wait, this is two...) - stretch all the cables out before you adjust the brakes and gears. Give them a fucking MASSIVE pull to make sure. And with the spin on rear sprocket cheap chinese shit bikes, put the fucker in first gear and ride it with the brakes on to tighten the block. You'll be amazed what a difference it makes.  |
| Cillit-BANG |
 Posted: 18:07 - 01 Dec 2007 Post subject: |
Or, whilst you have the wheel out anyway to check the bearings, you can simply drop it onto the suitable tool which is permantly fixed in the engineers vice behind you, along with the cassete lock-ring tool  |
| UnknownStuntm... |
| G |
 G The Voice of Reason
| ZRX61 |
 ZRX61 Victor Meldrew
The last post was made 18 years, 222 days ago. Instead of replying here, would creating a new thread be more useful? |
