Gilera runner sp50
-Elliot-
PostPosted: 17:59 - 24 Oct 2007    Post subject: Gilera runner sp50 Reply with quote
does anyone know what size carb jet i need to help de-restrict?
i will have an aftermarket exhaust aswell. so i just need to know how many sizes to go up.
thanks
SM.Morgan
PostPosted: 18:06 - 24 Oct 2007    Post subject: Reply with quote
58 main jet should be fine for de-restricting and the exhaust.
Harley XR1200
-Elliot-
PostPosted: 18:10 - 24 Oct 2007    Post subject: Reply with quote
ok, thanks
cheekythomas
PostPosted: 19:48 - 24 Oct 2007    Post subject: Reply with quote
Depends on the age as if its a pre-2003 model with a dellorto carb its a 64 as std... so a 58 will be useless Wink
More details please Wink
-Elliot-
PostPosted: 20:40 - 24 Oct 2007    Post subject: Reply with quote
its a W reg, so 2000 model, not sure what carb yet, will check tomorrow
cheekythomas
PostPosted: 21:00 - 24 Oct 2007    Post subject: Reply with quote
Cool... make sure you stay well away from the 58 jet then, on a W-reg it will be FAR FAR FAR too small! Wink
It will either be a 14mm weber carb or a 17.5 dellorto.. easy to tell as they both have it clearly written on them! Very Happy
-Elliot-
PostPosted: 22:51 - 24 Oct 2007    Post subject: Reply with quote
ok thank you, i have been told i can further derestrict by changing the rollers and removing the washer in the variator.
what weight rollers would i need if i wanted a balance between good acceleration and good top speed, but a bit more speed than acceleration?
thanks
cheekythomas
PostPosted: 18:07 - 25 Oct 2007    Post subject: Reply with quote
Rollers are not a restriction so dont think of them as such as it gets too confusing...
If your running a standard exhaust and planning on derestricting the bike then you can drop from 6.4gram standard to 5.5grams... top speed will be the same as rollers dont effect speed, thats controlled by size of the pulleys and the ratio of the final drive gears... but reducing the roller weight will allow the bike to rev harder before the gearing changes which will keep the bike in its powerband better... if you go down the sports exhaust then youll need to go even lighter as they work on an expansion chamber system which moves the powerband even higher up the rpm range.
Derestrict the exhaust, drop 1gram on the rollers, fit a bigger main jet and remove the variator washer and it will go well (aslong as its not done 20,000km and never had a piston and ring kit)
-Elliot-
PostPosted: 18:36 - 25 Oct 2007    Post subject: Reply with quote
what size jet though?
davidlewtas16
PostPosted: 20:31 - 24 Dec 2007    Post subject: Reply with quote
iv had a 76 on mine i changed it to a 56 and it makes it bog out after 20mph ud be best off with 58 up to 78 and the rollers are anoing iv had loads in and mines a 5.5g but yours cud be eneything m8 just find out wich 1s work best
The last post was made 18 years, 1 day ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.65 - MySQL Queries: 14 - Page Size: 62.66 Kb
