| Billd |
 Billd Nova Slayer
 Posted: 16:38 - 17 Feb 2008 Post subject: Neutral Light |
Hi, when I pull my clutch in the neutral light comes on, when I let the lever out it goes off (except if the bike's in neurtal ) Any ideas?? |
| Itchy |
 Itchy Super Spammer
 Posted: 16:42 - 17 Feb 2008 Post subject: |
sounds exactly like what my NTV is doing TBH , not diagnosed the problem though .. ____________________ Spain 2008France 2007Big one 2009 We all die. The goal isn't to live forever, the goal is to create something that will. In the end, your life will flash before your eyes. Make sure it is worth watching. |
| stinkwheel |
 Posted: 17:19 - 17 Feb 2008 Post subject: |
Sounds like it could well be a bad connection on the clutch switch. What bike is it.
Does the engine cut out when this happens?
Does it stay on all the time when the bike is in neutral. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Billd |
 Billd Nova Slayer
 Posted: 17:44 - 17 Feb 2008 Post subject: |
It's a 1982 CB750 Custom & the problem doesn't affect the running at all. The light is on all the time unless it is in gear with the clutch out  |
| garyd |
 garyd Brolly Dolly
 Posted: 18:23 - 17 Feb 2008 Post subject: |
Replace neutral switch  ____________________ CRF230 all you need |
| tutton |
 tutton World Chat Champion
| stinkwheel |
 Posted: 17:50 - 18 Feb 2008 Post subject: |
| garyd wrote: | Replace neutral switch  |
Unlikely to be the neutral switch causing the problem.
I suspect your clutch switch is duff. There are usually three wires. One connects to earth, one connects to the neutral switch, the third connects to the starter motor relay.
What should happen is when the clutch is out, the relay wire is connected to the neutral switch. When the clutch is in, the relay wire is connected to earth.
It would appear in your case that when the clutch is pulled in, the neutral switch is being connected to earth also/instead. Now you need to find out why.
I'd suggest cleaning the switch first off. Then testing it with a multimeter, then checking it has been connected up correctly and finally checking the wires leading away from it for damage/shorts.
It would be interesting to see if your starter motor also works when in gear with the clutch out (carefully), if it does, there is a good chance someone has connected the switch up incorrectly. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| garyd |
 garyd Brolly Dolly
 Posted: 22:51 - 18 Feb 2008 Post subject: |
Good info Stink  ____________________ CRF230 all you need |
The last post was made 18 years, 34 days ago. Instead of replying here, would creating a new thread be more useful? |
