TZR Breather Pipe?
Durkiee
PostPosted: 14:45 - 16 Jan 2010    Post subject: TZR Breather Pipe? Reply with quote
Hi there Just wondering Because i carnt remember when i took it off about 4 month ago the breather pipe i think that's what it is any way that comes out of the back of the petrol tank will petrol come out of it and where is the pipe went to go by the way im a total novice rebuilding a TZR with the memory span of a goldfish ha-ha
kind regards Durk .
st3v3
PostPosted: 23:57 - 16 Jan 2010    Post subject: Reply with quote
If it's a pipe that comes from the tank and is below the line of petrol then I'd guess it will leak. Where it goes... have you got a manual?
Durkiee
PostPosted: 00:06 - 17 Jan 2010    Post subject: Reply with quote
Yeah thats what i was thinking but then again Ive forgotten where it went to when i took it off ha-ha ... yeah Ive got the manual but for some reason it covers every thing but that ha-ha
PostPosted: 00:17 - 17 Jan 2010    Post subject: Reply with quote
Probably either the fuel tank breather (which will be above the fuel level), or it will be a drain pipe from around the fuel filler (drains away any water from around the cap so it doesn't accumulate and then drop into the tank when you open it).
In neither case should petrol come out of that pipe.
st3v3
PostPosted: 00:44 - 17 Jan 2010    Post subject: Reply with quote
Are there any pics in the manual that contain said pipe and give an indication where the pipe leads off to?
Durkiee
PostPosted: 01:12 - 17 Jan 2010    Post subject: Reply with quote
none at all to say its hayne's manual haha they're meant to know every thing haha
PostPosted: 12:45 - 17 Jan 2010    Post subject: Reply with quote
Nothing much in the Yamaha TZR manual either.
oldbiker
PostPosted: 19:45 - 17 Jan 2010    Post subject: Reply with quote
I hope its a 250 cos` there the only tzr`s that I have any experience of.
Inside the tank the breather pipe is steel and sits near the filler cap it is bent and welded to a point low down near the back of the tank, this is where you connect the plastic breather pipe to.
The plastic pipe on mine goes down the left hand side of the bike behind the plastic side panel. The total length of the pipe is about 8 inches. When I fill my tank to the VERY TOP it overflows and this petrol drips down near the left hand, outside of the engine.
I`m only guessing but I would imagine that yours would be vaguely similar.
Any help Question
It`s all powerfull white mans magic
https://i897.photobucket.com/albums/ac178/tzrsteve/album%201/035.jpg
Durkiee
PostPosted: 19:52 - 17 Jan 2010    Post subject: Reply with quote
Any help Question
Great Help Mate Thanks its not a 250 its a 125 but there basically the same other than engine size but the info you gave sounds about right ha-ha much appreciated thanks kind regards Durk
The last post was made 16 years, 287 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.24 - MySQL Queries: 14 - Page Size: 62.83 Kb
