| WildGoose |
 WildGoose White Van Man
 Posted: 17:38 - 24 Feb 2003 Post subject: Sump Plug/Oil Filter Housing Torque Settings |
changed my oil and filter today, very satisfying, and messier than i was ready for (apoligies about the patio dad i'll sort it out)
sump plug torque was not listed in any manual i own, same goes for the oil filter housing bolt, so i was wondering what you guys used when you did yours? and how important it actually is?
i did both oil filter housing bolt and sump plug to 55Nm cos thats what the manual listed as general guide for bolts of 12mm thread diameter (which the sump plug had) the oil filter housing bolt was like 18mm but i did that to the same torque so its easier to remember
any thoughts or advice on this?
P.S anyone who hasnt changed their oil yet, make sure your other hand (the one that isnt holding the wrench) is poised ready to catch the washer, before it falls into a big greasy tub of dirty oil it wasnt fun trying to find it and get it out ____________________ So in other words, he stopped you for being flagrantly in posession of a motorcycle in direct contravention of the Hippies, Darkies and People Whose Face I Don't Like The Look of (Police Powers) Act. 1976 |
| TiN |
 TiN Pocket Tin
 Posted: 17:45 - 24 Feb 2003 Post subject: |
Hmm, it doesn't mention it in my Haynes manual either...but yeah, just follow the general settings for the thread diameter.
You don't wanna over-tighten the bolt lest it breaks (not pleasant at all), and obviously it doesn't want to be too loose lest you want to lubricate the road with Castrol GPS  ____________________ TiN
dotgems.net |
| WildGoose |
 Posted: 18:37 - 24 Feb 2003 Post subject: |
lubricate the road and your back tyre doesnt really bare thinking about ____________________ So in other words, he stopped you for being flagrantly in posession of a motorcycle in direct contravention of the Hippies, Darkies and People Whose Face I Don't Like The Look of (Police Powers) Act. 1976 |
| G |
 G The Voice of Reason
 Posted: 20:00 - 24 Feb 2003 Post subject: |
I think my zx6 was 35ish.
55 should be fine.
Wasn't the washer over the sump plug
When undoing sump lugs I usually undo it the last bit by hand, pushing up as I do it, this way the oil is trapped unitl it's completley undone then whit it away.... okay you get a bit of oil on your hand but not nearly as much and you don't cover your tools in it  |
| Robby |
 Robby Dirty Old Man
| G |
| Robby |
 Robby Dirty Old Man
| Kickstart |
 Kickstart The Oracle
| kev |
 kev I Hump Things
| Kickstart |
| PikeyNSR |
 PikeyNSR Nova Slayer
| WildGoose |
 Posted: 22:53 - 24 Feb 2003 Post subject: |
fair point, but im not interested in doin things half heartedly (sp) its the way i am, if there is a manual for something i'll read it, if there is a torque setting i'll use it, im not exactly short of time as a mechanic in a bike shop may be, so i'll do things by the book, till i get a feel/confidence for what im doing, then i can go about bodging things
| Quote: | Wasn't the washer over the sump plug |
yes, but having no clue as to what to expect when removing the sump plug, i unscrewed it bout half way with a ratchet, then oil started pissing out everywhere it could (hot oil at that) in theory the tray should have been under the bike at this point, but i didnt engage that thought process before hand so i whipped the tray under and undid the rest of the bolt by hand (with haste) the sump was tight and the washer was obviously fairly comfortable where it was, i went to get a paper towel to dry the sump plug a bit, then remembered there should be a washer, felt around the sump, and there was nothing there
i was faced with a black tub of oil and a missing washer
one last question, the manual mentioned smearing some fresh oil round the rubber seal, faced with three possible rubber seals i smeared them all, what is the purpose of this?
and i remember reading you should submerge the new oil filter in clean oil before installing it (i didnt) is there a reason for this? and should i have done that? ____________________ So in other words, he stopped you for being flagrantly in posession of a motorcycle in direct contravention of the Hippies, Darkies and People Whose Face I Don't Like The Look of (Police Powers) Act. 1976 |
| Kickstart |
| WildGoose |
The last post was made 23 years, 177 days ago. Instead of replying here, would creating a new thread be more useful? |
