Floating discs
Nebzor
PostPosted: 21:33 - 18 Jun 2008    Post subject: Floating discs Reply with quote
I've had someone round to look at the bike as a favour, and one thing he mentioned was my front discs.
Now he said that they (looked seized? cannae remember properly) and I should do something involving WD40 a nut and a bolt?
I thought that all a floating disc was was a disc with circular separators to allow the portion of the disc acted on by the pads to expand at a different rate to the inner portion.
Help? Embarassed
Peugeot Speedfight 2 - Honda VFR400 - Honda CB500
PostPosted: 21:44 - 18 Jun 2008    Post subject: Reply with quote
The are meant to float to allow the disk to move to stay parallel with the pads even when it warms up.
If they stick it is likely to be like having a warped disk.
Nebzor
PostPosted: 21:51 - 18 Jun 2008    Post subject: Reply with quote
How does one tell if they are sticking?
How does one fix said sticking?
vfr800
PostPosted: 22:44 - 19 Jun 2008    Post subject: Reply with quote
The discs may have just seized with road crud.
Get a nut and bolt just under the size of the hole in the floating part, put a washer each side and then tighten the nut and bolt up tight.
Now with a socket or spanner the size that fits the bolt try to turn the bolt, DONT use WD40 or oil to act as a lubricant, use brake or clutch cleaner. Once the bolt moves the small disc you can work it loose by using more cleaner wilst turning the disc.
Perform this task on all the small discs and that should return the disc to it's floating status. If it does'nt work your looking at warpred discs as prevously mentioned.
Worth a try! Ian
don't take it easy 'ride it like you stole it'
Nebzor
PostPosted: 19:19 - 20 Jun 2008    Post subject: Reply with quote
Thanks for your help.
Have done one of my discs (all the little circular things are turning when I get the bolt in, no awful screechy noises or anything) but it doesn't change anything with the disc.
Hope it isn't warped.
The last post was made 17 years, 296 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.86 - MySQL Queries: 14 - Page Size: 46.09 Kb
