| EssexNSR |
 EssexNSR Derestricted Danger
| hmmmnz |
 hmmmnz Super Spammer
 Posted: 05:46 - 30 Jun 2008 Post subject: |
pop the sump off and see if you get any purchase on the inside and keep screwing it through.
or unscrew it the way it went in.
thats hardly a reason for a engine rebuild, or something you'd even consider when doing a rebuild.
if you still can't get it, then you will have to drill a small hole in it and use a bolt extracter set,
or take it to your local welders and get them to weld a small bit of metal to it so you can unscrew the broken bit...
have fun
 ____________________ the humans are dead
I kick arse for the lord
Wiring Diagrams BIDNIP it bitches |
| EssexNSR |
| ms51ves3 |
 ms51ves3 Super Spammer
| Ben. |
 Ben. World Chat Champion
 Posted: 13:04 - 30 Jun 2008 Post subject: |
engine out sump off, new sump in
or grind a slot into it, flat head screw driver, mole grips, weld a bolt onto it, drill it out and use an extractor thingy majig. Thats the lot really.
enjoy  ____________________ follow my racing season
Race bike - R6
Road bike - sv650 |
| EssexNSR |
| Kickstart |
 Kickstart The Oracle
| dch |
 dch Two Stroke Sniffer
 Posted: 14:19 - 30 Jun 2008 Post subject: |
I'd go for the Dremel idea above, but you might also want to look at this:
https://www.jmldirect.com/Screw-Extractor-PS5616/
Given that it can cut into the rounded head of a screw, you might find that it can cut into your sump plug and take it out. |
| Frost |
 Frost World Chat Champion
| ncrn |
 ncrn World Chat Champion
 Posted: 14:34 - 30 Jun 2008 Post subject: |
The NSR has no sump, if you wanted to replace the case you would have to split the engine in half, no easy job. But if you do decide that is the only option I think I've still got that half of the engine casing that hasn't been sold yet. Unless its on the right side of the engine then no I don't. ____________________ Past: 55 Sym Jet, 91 ZZR250, 03 NSR125R. Present: 97 ER-5.
https://www.nsr125.co.uk - NSR Owners forum. |
| Kickstart |
| ncrn |
| Kickstart |
| bladerunner |
 bladerunner World Chat Champion
| Pete. |
 Pete. Super Spammer
 Posted: 16:32 - 02 Jul 2008 Post subject: |
Probably the only situation I would suggest using an easy-out. Drill the plug and wind it out. ____________________ a.k.a 'Geri'
The last post was made 17 years, 229 days ago. Instead of replying here, would creating a new thread be more useful? |
