1984 FZR400 Starting/Electrical Prob
richs20a
PostPosted: 18:43 - 30 Jun 2008    Post subject: 1984 FZR400 Starting/Electrical Prob Reply with quote
FZR400 - 1987
Was running fine, now wont crank.
Fuses all check ok (the smal block of 4 and also the main 30amp fuse).
Battery charged up good.
Lights and indicators, horn works ok, too.
WHAT can i check voltage wise etc? When i press the start button, the relays click like they are energising, but no start?
What is the mothodical approach to solving this, is was starting fine last night...... (only just bought it)
cheers
Coxyzxr
PostPosted: 20:24 - 01 Jul 2008    Post subject: Re: 1984 FZR400 Starting/Electrical Prob Reply with quote
richs20a wrote:
FZR400 - 1987
cheers
Starter solenoid corrosion or failure? the ignition box clicks but the bike just doesn't crack as it should just after that.
Check the connections and the fuse on the start solenoid, it looks like this https://cgi.ebay.co.uk/KAWASAKI-ZX6R-G-STARTER-SOLENOID-s87_W0QQitemZ260165233337QQcmdZViewItem?_trksid=p3286.m20.l1116, is usuall under the seat or rear tail fairing and covered in rubber sheath. Also a worn battery (charged up ok or no) 'can' give this problem (edit the fzr one may look like this https://cgi.ebay.co.uk/Yamaha-FZR400-Exup-3TJ-1990-G-Starter-Solenoid_W0QQitemZ270232440377QQcmdZViewItem?_trksid=p3286.m20.l1116)
**WAS FITTED "WRONG WAY ROUND" !** CANT ACCOUNT FOR THE STUPID !
TUG
PostPosted: 20:24 - 02 Jul 2008    Post subject: Reply with quote
Clicks but wont start, Get a volt meter across your battery mate. if the voltage is high like 12V+ then a little lower when u try an start it see if a new relay will sort it out, but the one in the link am not sure will work cos thats for a 3TJ which is a few models down the line see, but it may well be the same. Best to check an see.
Haz ER-5, innit!
richs20a
PostPosted: 20:49 - 02 Jul 2008    Post subject: found problem....... Reply with quote
the startr reelay was ok. All i did was jump off the starter with a think wire and in started fine. then, checked the 12v switched wire into the solenoid, which was ok........ meaning, aas i pressed the start button it gave the sol. a feed...... turns out the end of that wire was nearly hanging off and not giving good contact... replaced the small fitting and is now starting fine, thanks for the advice, it was priceless.....
regards.
TUG
PostPosted: 23:30 - 02 Jul 2008    Post subject: Reply with quote
Excellent! Have fun on the fizzer, there a hooligans bike.
Haz ER-5, innit!
The last post was made 17 years, 237 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.26 - MySQL Queries: 14 - Page Size: 44.68 Kb
