A CG125 Problem
rallymark1
PostPosted: 08:03 - 30 Jul 2008    Post subject: A CG125 Problem Reply with quote
I just aquired a CG125 1982 (I believe, old Y reg)
Anyways some clever person thought he could get it running by ripping all the electrics back to the stator. Now i only have 5 wires coming from the stator, a Coil (with (what i believe to be) the condensor on the side of the coil?) and then one wire coming off of the actual Coil pack.
Now my two questions are:
1) Does this older model CG have a CDI Unit suposed to be in the electrical System? and therefore I'm missing that.
2) What do the 5 wires coming from the stator do in comparision to Live, Ground, etc, as well as the wire coming from the Coil?
If you can help, it would be greatly appricated. Even a wiring diagram if any knows of one? This is only for a mess around for the field as there is no lights and it is in a brave state.
Thanks
Suzuki TS185 (1978), Yamaha YZ125 (1989)
virus
PostPosted: 08:49 - 30 Jul 2008    Post subject: Reply with quote
Points ignition on that one, should be visible through the hole in the flywheel.
Search for wiring diagrams, theres one thread floating around with pretty much every wiring diagram on it.
John
own: 81 xs1100g...
The last post was made 17 years, 193 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.08 - MySQL Queries: 14 - Page Size: 32.16 Kb
