| Author |
| Jai466 |
 Jai466 Spanner Monkey
| Back to top |
| The Artist |
 The Artist Super Spammer
| Back to top |
| map |
 map Mr Calendar
 Posted: 09:51 - 09 Oct 2008 Post subject: |
Take top of reservoir (make sure turn bars to it's level). Cover with clean cloth to stop muck getting in and then tie brake lever back to the bars (with bungie, gaffer tape, etc.). Leave overnight (or during the day) but try and avoid doing this when the weathers damp/wet (or if you've got a garage no problems).
This forces the air slowly up to the reservoir. Remember to put the top back on
Another tips is to take a rubber mallet and gently tap the caliper to force air up the lines.
Another lace where air gets trapped is the banjo bolt into the reservoir. Crack this open (put a cloth underneath to prevent spilling onto bodywork/paintwork) and then tighten it.
HTH  ____________________ ...and the whirlwind is in the thorn trees, it's hard for thee to kick against the pricks...
Gibbs, what did Duckie look like when he was younger?  |
| Back to top |
| Jai466 |
| Back to top |
| Jai466 |
 Posted: 09:56 - 09 Oct 2008 Post subject: |
| map wrote: | Take top of reservoir (make sure turn bars to it's level). Cover with clean cloth to stop muck getting in and then tie brake lever back to the bars (with bungie, gaffer tape, etc.). Leave overnight (or during the day) but try and avoid doing this when the weathers damp/wet (or if you've got a garage no problems).
HTH  |
Thanks mate.
Sorry is the banjo bolt the only bolt which connects brake pipe to the master cyclinder (reservour)? |
| Back to top |
| Whosthedaddy |
 Whosthedaddy Super Spammer
| Back to top |
| Jai466 |
| Back to top |
| Jai466 |
| Back to top |
| map |
 map Mr Calendar
| Back to top |
| Whosthedaddy |
| Back to top |
| Whosthedaddy |
| Back to top |
| Jai466 |
| Back to top |
| Jai466 |
| Back to top |
| Kickstart |
 Kickstart The Oracle
 Posted: 13:42 - 09 Oct 2008 Post subject: |
Personally I would say sort it.
Where are bubbles visable?
One problem can be that when the bleed nipple is undone air can get down the threads and into the caliper. Normally only undoing it a small amount stops this. However might be worth trying again, but pull the lever hard , keep it pulled and then slacken off an retighten the bleed nipple (ie, undo it slightly and allow some fluid / air out but tighten it as the lever reaches the bar so air has no chance to get back in). Repeat that a fair amount.
Also check the bleed nipple is at the highest point on the caliper (assume you aren't trying to use a bleed nipple banjo bolt, normally a bodge people use when they have sheered off the bleed nipple).
As mentioned above it is common to get a bit of air stuck in the top banjo bolt. To get rid of this wrap some cloth around the banjo bolt, pull the lever and crack off the banjo bolt and tighten it again, then you can release the lever.
| Back to top |
| Jai466 |
| Back to top |
| Whosthedaddy |
 Posted: 14:08 - 09 Oct 2008 Post subject: |
Google says:
https://www.sideways-technologies.co.uk/images/m2.jpg
I've had bubbles in the tube that may be likened to that of a glass of beer, the more you pump the brake lever, tighten the nipple, top and repeat should start to see less and less bubbles, or even just larger bubbles that are easier to get out of the tubing. |
| Back to top |
| NiteMare |
 NiteMare Spanner Monkey
| Back to top |
| Jai466 |
| Back to top |
| Jai466 |
| Back to top |
| Kickstart |
| Back to top |
| Jai466 |
| Back to top |
| Kickstart |
 Posted: 14:43 - 09 Oct 2008 Post subject: |
Air gets stuck in the top banjo bolt. Basically you want to have the lever pulled and then crack the banjo off a touch and retighten it (use cloth around it so any fluid that gets squirted out is caught).
There are likely 2 holes in the bottom of the reserviour. There is likely one fairly large hole that allows fluid to get behind the piston. This will be nearer the lever is is pretty irrelevant. There will also be another hole further from the lever that is probably a fair bit smaller. This leads into the useful part of the master cylinder and it is from here that you want no bubbles to come from.
| Back to top |
| NiteMare |
| Back to top |
| Jai466 |
| Back to top |
| rotax81 |
 rotax81 Nearly there...
 Posted: 19:03 - 09 Oct 2008 Post subject: |
apart from all the other techniques above. if there is still a stream of tiny bubbles coming up then i normally start the bike up and let it idle while gently pumping the lever. the vibrations help the bubbles rise.
the normal way i do it is to use an easibleed kit but fit it to each caliper nipple rather than the cap.
mind taking it out if you are unsure of the brakes. they can be unpredictable with any air in there  ____________________ ZX636C6F road. ZX636C1H track. ZX7R redundant. ZX0.5R minimoto as ornament.
Audi A4 Avant 1.9TDi and VW Transporter 2.5TDi 888 Special (no mot and tax lol) |
| Back to top |
The last post was made 17 years, 358 days ago. Instead of replying here, would creating a new thread be more useful? |
