| Graham88 |
 Graham88 World Chat Champion
| mentali-juan |
 mentali-juan Scooby Slapper
| Jamie S |
 Jamie S World Chat Champion
| carvell |
 carvell Scuttler
| Whosthedaddy |
 Whosthedaddy Super Spammer
| MattHirst |
 MattHirst World Chat Champion
 Posted: 15:27 - 01 Nov 2008 Post subject: |
The question must be asked, why do you need one so long?  ____________________ It's all fun and games until someone gets hurt, then it's bloody hilarious!!! |
| Whosthedaddy |
| Graham88 |
| SlimRick |
 SlimRick World Chat Champion
| mentali-juan |
| Cigaro |
 Cigaro World Chat Champion
 Posted: 15:58 - 01 Nov 2008 Post subject: |
Why not cut the end off the existing cable, get a junction box and join it to a normal-length extension? Then put some silicone in the junction box to seal it up.  |
| Graham88 |
| SlimRick |
| Cigaro |
| MattHirst |
| SlimRick |
| Finglonga |
 Finglonga World Chat Champion
 Posted: 16:16 - 01 Nov 2008 Post subject: |
| Graham88 |
| tatters |
 tatters Exxon Valdez
 Posted: 08:03 - 02 Nov 2008 Post subject: |
If your going to run power to your garage at lest do a proper job and not run a pvc flex down the garden
What you need to 3 core 2.5mm SWA (Steel wire armoured) cable, all eletrical supply shops will sell this and the comment about non-quailfed people not being able to buy cable is utter bollacks.
From your consumer unit you need to run a 2.5mm 3 core cable this is normaly twin and earth but l think a new round fire reistance type is sold theses days in its place coming off a 20 amp RCD (2.5mm SWA is rated up to 31 amps, 2.5mm twin and earth 24 amps), then to a metal clad juntion box near the outside of the house ie fixed under the floor etc enter the cable to the box through a stuffing gland or a grommet, make the connection between the cable cores from the consumer unit and SWA cores with a suitble size plastic termainal connector strip (know as a chocolate block connectors) in the juntion box.
From the jubtion box you can run the SWA to the garage and into another juntion box using brass SWA glands at either end (the cable entering the house and into the garage depends what you can do but for example mine goes out through a air brick on the side of the house straight underground then up through the garage floor, the SWA cable needs to run along near the edge of your garden buried in a trench at lest 50cm deep some people also cap the trench with bricks etc for extra protection.
From the juntion box in your garage you can now fix a metal clad socket onto the side (single or double max total load of 20 amps on what ever you run of them) with a conduit copular and bushs which you run the live netural and earth cores through from the swa to the sockets connections, if you wanted to have more sockets lights etc you need to use higher rated cables and a larger RCD.
Examples:
Juntion box
https://www.diy.com/diy/jsp/bq/nav/nav.jsp?action=detail&fh_secondid=9289900&ecamp=trf-005&CAWELAID=245541196
100 meters of 2.5mm 3 core SWA (live,netural,earth) can be picked up for around £60
RCD https://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=230277038278&cguid=011adc1511d0a0e20330dd80ff0ee6fa
https://cgi.ebay.co.uk/10-x-12-30Amp-Connector-Strips_W0QQitemZ330281505591QQcmdZViewItem?hash=item330281505591&_trksid=p3286.c0.m14&_trkparms=72%3A1298%7C66%3A2%7C65%3A12%7C39%3A1%7C240%3A1318
SWA glands
https://cgi.ebay.co.uk/10-N0-BW20K-SWA-GLANDS_W0QQitemZ280281286717QQcmdZViewItem?hash=item280281286717&_trksid=p3286.c0.m14&_trkparms=72%3A1432%7C66%3A2%7C65%3A12%7C39%3A1%7C240%3A1318
Single 13 amp socket
https://cgi.ebay.co.uk/5-x-Metal-Clad-13-Amp-Switched-Single-Socket-and-Box_W0QQitemZ130265316504QQcmdZViewItem?hash=item130265316504&_trksid=p3286.c0.m14&_trkparms=72%3A1432%7C66%3A2%7C65%3A12%7C39%3A1%7C240%3A1318
This is just a genral guide l would bother doing this unless your pretty sure you know what your doing or have a mate that does. ____________________ Past:NRG50,AF1125(x2),NSR125RR,ZZR250,CX500,VFR400,KR1S,ZZR600(x2),CB400N,YZF1000(x2),KH125,Z200,FX400R,CBR954RR(x2)GPZ500S,GT550,VFR750F(x2),RD350N,XR650R,CBR600F,CB250,KDX250,YZF750R,CRM250,400EXC,KLR650,TTR600RE,DR350S,R100GSPD,RGV250,VMAX1200,DL650,KZ750 Present:G650XC,C12,CRF450X,1190ADV |
| carvell |
 carvell Scuttler
The last post was made 17 years, 346 days ago. Instead of replying here, would creating a new thread be more useful? |
