| spitfire123 |
 spitfire123 Could Be A Chat Bot
 Posted: 16:24 - 16 Nov 2008 Post subject: mito electronic power valve? |
hi all,
i stripped my bike a few weeks back including pulling the engine out etc and re-building it....
and when i bought it (3 weeks ago) the electronic motor for the powervalve used to move a quater of a turnclockwise then back to center...
but now ive put a new battery in to the bike, it is no longer moving when i turn the ignition on like it used to.
the battery before was completly dead? did it move to tell me the battery was on its last legs? and dosent do it now as its a BRAND NEW battery??
or has it packed up?
ANY INPUT WOULD BE GREAT...thanks  ____________________ You won't be able to eat my dust......As it'll settle before you get there. |
| Gazdaman |
 Gazdaman I did a trackday!!!
| spitfire123 |
| spitfire123 |
| kev... |
 kev... Nova Slayer
| spitfire123 |
| Gazdaman |
| spitfire123 |
| Gazdaman |
| spitfire123 |
| spitfire123 |
| Gazdaman |
| kev... |
 kev... Nova Slayer
| spitfire123 |
 Posted: 19:38 - 16 Nov 2008 Post subject: |
thats what i was thinking but ive checked all the connections and they seem fiine
what do i do from here..
i dont get it a sit jults whn you turn it on??
help! ____________________ You won't be able to eat my dust......As it'll settle before you get there. |
| Gazdaman |
| Kickstart |
 Kickstart The Oracle
 Posted: 20:04 - 16 Nov 2008 Post subject: |
The power valve should open and close when you switch the ignition on. It is operated by a servo and controlled by a control unit. The control units do go pop quite often. You might find that it opens the valve but doesn't close it (not that you will notice, as it will open it and then never close it to open it again). You might be able to close the valve manually and notice it open the next time you switch on the ignition.
Think the later ones do have a fuse on the wire to the control unit, or between the control unit and the servo. Think the problem seems to be that when the valve gets stuck or is badly adjusted is that the servo just draws more current and pops the circuits in the control unit (or the fuse if you are lucky enough to have one).
Last I heard was the 3X (Cagiva importers at the time) would only warrenty a new control unit if it was sold with a new servo unit.
To be honest the first thing I would do is to disconnect the cables to the power valve and see if the servo still operates. Possible you have connected the cables the wrong way round and so jammed it. Hopefully without popping the control unit.
| spitfire123 |
| Kickstart |
| spitfire123 |
| spitfire123 |
| Tricolor Fan |
 Tricolor Fan Trackday Trickster
 Posted: 22:42 - 16 Nov 2008 Post subject: |
The first unit is a CDI not a PV control unit, Keith is referring to the second one which is a PV Control unit.
They can burn out if the PV isn't adjusted correctly. Have you the cleaned the PV blade and adjusted the it as per the workshop manual? ____________________ Give me ambiguity or give me something else. |
| Tricolor Fan |
| spitfire123 |
| Tricolor Fan |
| spitfire123 |
The last post was made 17 years, 313 days ago. Instead of replying here, would creating a new thread be more useful? |
