Pilot screw checking/setting -Worth doing
Smooth
PostPosted: 12:25 - 08 Dec 2008    Post subject: Pilot screw checking/setting -Worth doing Reply with quote
My bike has never been good at idling until thoroughly warmed-up and there was always a slight 'hiccup' (that could result in a stall) whilst stationary with no throttle.
Cleaning and balancing the carbs a while ago meant that on the move the bike was fine, but idle wasn't good without a slight opening of the throttle.
I finally got around to adjusting the pilots the other day and discovered that the anti-tamper caps had already been removed by someone else and that the screws were wound out quite a way -different on each carb.
Setting the screws to the richer end of the factory settings - 1 3/4 turns out, the improvement was significant. The bike idles smoothly on closed throttle with no 'hiccuping' and I was able to reduce the idle speed. Throttle response from closed seems improved too. the bike is going to be in great nick when I come to sell it
I'm assuming that the pilots had been adjusted in the past as a bodge to compensate (compromise) for the previously clogged pilot jets.
If you've got a second-hand bike it's worth checking the pilots and (on a parallel twin) it is much quicker and easier than I expected it to be. The simple tweaks are often the best! Smile
TDM850
The last post was made 17 years, 305 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.44 - MySQL Queries: 14 - Page Size: 28.31 Kb
