Running (badly) on choke, and stalling without
Visitor Q
$25 whore
PostPosted: 18:01 - 15 Dec 2008    Post subject: Running (badly) on choke, and stalling without Reply with quote
Hey all, my CBR 600 FT (1996) seems to be dying Crying or Very sad
I've had this rattle for a fortnight or so which hasn't seemed to affect the actual performance.
Now out of the blue the bike died by the end of my road. Sounded like fueling difficulties so I chucked it onto reserve (about 20 miles earlier then normal) and then it still wouldn't run properly.
It would raspily run with the choke fully on, but sounded abit like it was oil seizing (I've checked that and the level is fine*) and wasn't exactly generating power. Soon as the choke went off it would stall within a few seconds.
Can all that be ascribed to loose headers/manifolds? As that's what I'm pretty sure I'm dealing with.
m0l0t0v
PostPosted: 18:26 - 15 Dec 2008    Post subject: Reply with quote
I had something like that happen with the Hornet ages ago. The actual problem was just a screwed up tube.
From the fuel tap feel the small tube for any rips or tears. It should go from the tap to the back of the cylinders. Found the problem was that it had tarnished at the end. All I had to do was cut it slightly and put it back in. This little tube created pressure and "pulled" the diaphragm of the fuel tap and let petrol flow. No harm in checking and it takes like 1 minute. I was also off the road because of that little dick for a month Rolling Eyes
My Hornet at that point would run on choke but if youi took it off it would die. And it did sound like fuelling problems (which it was)
Could also check to see if petrol is getting into the carbs?
Visitor Q
$25 whore
PostPosted: 18:32 - 15 Dec 2008    Post subject: Reply with quote
I really should learn to do more bikey things. Haven't 'checked' my carbs in the 3 years I've owned it (nearly 4 now).
Will check the fuel tank hoses, but can't help thinking it's related to the rattle Thinking
m0l0t0v
PostPosted: 18:53 - 15 Dec 2008    Post subject: Reply with quote
I never checked them either unless I had to drain the diesel and the time the pipe had tarnished.
I can't comment on the rattle though.. But checking to see if the carbs have petrol in (by usng the drain screw) and checking the pipes takes literally a couple of minutes and you can cross fuelling problems of your list or be safe in the knowledge it's jut a pipe which is cheap. Razz
Visitor Q
$25 whore
PostPosted: 19:05 - 15 Dec 2008    Post subject: Reply with quote
Again, something I should know Embarassed
Ah well, I'll check haynes.
I've just found out you can buy exhaust springs off of ebay fairly painlessly. The bugger is that I can't seem to find any short enough for the manifold end (like <50mm). I'm hoping that combined with the stuff suggested in the rattle thread might stop it.
I'm pretty certain I can hear it blowing from the port, which could be causing a lot of problems.
After that I'll go into full panic.
Oh and the * from the OP was about oil level checks. With a screw cap dipstick thing, I know the bike is meant to be upright when you check the level. But are you meant to screw up the dipstick or just rest it in the hole?
yen_powell
PostPosted: 19:16 - 15 Dec 2008    Post subject: Reply with quote
Try wacking your 'famous for failing' (my bike has the same one) fuel pump with a spanner to see if the problem goes away temporarily.
XT1200Z and a DR350 in bits
m0l0t0v
PostPosted: 19:23 - 15 Dec 2008    Post subject: Reply with quote
Laughing I thought I was bad!
The screw will be just a small (flat head from what I remember) at the bottom of the carbs and you should be able to reach all 4 (2 from one side and 2 from other) and just undo them and leave it until no petrol comes out (if any) and then try starting up the bike. If it doesn't start up (without throttle) then use some throttle to hopefully get petrol into the carbs. If after that there's no petrol in the carbs then you know your problem Razz
As for checking oil levels you just rest it. And obviously upright s you know Wink
Visitor Q
$25 whore
Ah, didn't know they were tempermental. Will have a listen, but it was only replaced about a year ago (albeit second hand).
Visitor Q
$25 whore
PostPosted: 19:36 - 15 Dec 2008    Post subject: Reply with quote
Shh you. I've fitted a clutch all by myself Wink And I'm a diva at brake systems.
Just little fiddly things hidden behind a half hour fairing removal... pff
Will have a look at the carbs. They could probably do with a drain by now.
m0l0t0v
PostPosted: 20:36 - 15 Dec 2008    Post subject: Reply with quote
Come sort my brakes out and I'll give you a hand on the pipes and carbs Wink
sickpup
Old Timer
PostPosted: 20:53 - 15 Dec 2008    Post subject: Reply with quote
So you've owned the bike nearly 4 years now, ever changed the fuel filter?
yen_powell
PostPosted: 23:31 - 15 Dec 2008    Post subject: Reply with quote
The contact breakers inside the plastic end cap of the pump weld themselves shut. Mine usually last anywhere between 20,000 and 40,000 miles each. How many miles has your secondhand one done?
sickpup
Old Timer
PostPosted: 23:33 - 15 Dec 2008    Post subject: Reply with quote
Shouldn't do, mine last about 80k before I wear the contact breaker out.
Visitor Q
$25 whore
PostPosted: 23:54 - 15 Dec 2008    Post subject: Reply with quote
Aye, got a brand new one when my fuel pump shuffled off this world.
Just the man I wanted to PM though, I'm sorting out some flue sealant to do the headers with (ala Geri's suggestion) and I could really do with more manifold springs. The problem is the buggers are quite little, ~50mm unsprung (for a blue flame) and all the ones on ebay are 60+mm. Any chance you have any in stock?
sickpup
Old Timer
PostPosted: 10:59 - 16 Dec 2008    Post subject: Reply with quote
Not in stock but I will see if they're available.
Visitor Q
$25 whore
PostPosted: 14:13 - 16 Dec 2008    Post subject: Reply with quote
Ta mate. I'm not certain what size they are though, so maybe a couple of 40mm and 50mm would be more prudent. Don't want them going twang, but need them under a fair bit of tension.
Will probably take it all apart and flue sealant it up as well Thumbs Up
sickpup
Old Timer
PostPosted: 14:18 - 16 Dec 2008    Post subject: Reply with quote
Exhaust springs are available in 55mm, 70mm and 85mm. All cost £1.10 each.
Visitor Q
$25 whore
PostPosted: 14:44 - 16 Dec 2008    Post subject: Reply with quote
Is that how small they go Shocked
Ah well, must be that size. Unless you've heard BlueFlame ones are especially fiddly.
How can I order a few of them, and do you know how long they will take roughly?
PostPosted: 14:56 - 16 Dec 2008    Post subject: Reply with quote
Split vacuum pipe would result in air getting into the inlet of one of the cylinders, making it run lean and also having much the same effect as having that cylinders carb massively out of balance.
yen_powell
PostPosted: 15:25 - 16 Dec 2008    Post subject: Reply with quote
I've had 3 standard Honda/Mitsubishi pumps from new, plus a secondhand CBR600 one and they usually last 40k each, two of those were the 'new upgraded it won't fail this time sir' versions. I have also had a Mikuni vacuum pump which was strangely fine for 40,000 miles then started playing up.
I am currently running a Facet solid state type pump which is a third of the cost of a Honda genuine pump. Time will tell if it's going to get past my magic 40,000 miles wall.....
sickpup
Old Timer
PostPosted: 17:01 - 16 Dec 2008    Post subject: Reply with quote
Never had that problem with them although i do have a far few failed ones in a box.
yen_powell
PostPosted: 18:50 - 16 Dec 2008    Post subject: Reply with quote
I pulled a few apart out of curiosity to see what the points looked like. I have seen a few solutions to the problem, which seem to involve calming the spark down with some sort of supressor to slow down the wear on the contact faces. I will know in another 20-30,000 miles if the Facet solid state version of the pump is any better or if I should just treat bike fuel pumps as a service item.
m0l0t0v
PostPosted: 00:35 - 17 Dec 2008    Post subject: Reply with quote
Wouldn't it stop fuel getting to the carbs though? Or is that as well as?
chillpill
PostPosted: 13:28 - 17 Dec 2008    Post subject: Reply with quote
dont know much about 4-stokes but im gona throw it out there anyway .......... valve clearances Confused ?
Visitor Q
$25 whore
PostPosted: 15:00 - 17 Dec 2008    Post subject: Reply with quote
Funnily enough they are well overdue, but I can't imagine they would suddenly (literally overnight) cause problems.
The last post was made 17 years, 307 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 0.96 - MySQL Queries: 16 - Page Size: 151.25 Kb
