| Drew |
 Drew Banned
 Posted: 23:01 - 14 Dec 2008 Post subject: Carb icing or not? |
I've searched and found THIS which is exactly the same problem as I have.
Start up, and it idles fine.
If I slow in traffic or for a junction, it stutters as if it is running on 3 cylinders, (have to dip clutch and rev it to keep it alive) but once the revs are up again, it takes off again.
Everytime I slow to a stop, it cuts out. (starts up totally fine again)
Tested, and when on the move, if I dip clutch, the revs drop and it cuts out. (let out clutch to jump start again)
In the thread I linked to, Keith says it isnt carb icying, so what is the problem, and how to fix it?
ps, bike is 98 gsxr srad. |
| MaybeGuy |
 MaybeGuy Super Spammer
 Posted: 23:02 - 14 Dec 2008 Post subject: |
ive got the same bike, same problems.... yes, its carb icing. ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
| Whosthedaddy |
 Whosthedaddy Super Spammer
| Kickstart |
 Kickstart The Oracle
 Posted: 23:08 - 14 Dec 2008 Post subject: |
| Drew |
 Drew Banned
| Whosthedaddy |
| Drew |
 Drew Banned
| sickpup |
 sickpup Old Timer
| MaybeGuy |
| Kickstart |
| andys675 |
 andys675 World Chat Champion
| Drew |
 Drew Banned
 Posted: 23:37 - 14 Dec 2008 Post subject: |
So what is the problem if it isn't icing, and more to the point, how can I fix it?
I tried a little choke, it stopped it cutting out, but taking a roundabout at 4000 revs (with no throttle) while braking didnt feel too safe
As Sickpup says, high revs, high speed, there is no problem |
| Kickstart |
| Drew |
 Drew Banned
| Kickstart |
 Posted: 00:02 - 15 Dec 2008 Post subject: |
Carb icing problems come from the water vapour in the air freezing and building up in the carb. That might block a jet or jam the slide.
On a CV carb (ie, most carbed 4 strokes) the mixture for most of the rev / throttle range is controlled by the needle jet. The needle part of this is mounted in the slide, and the slide moves itself depending on intake vacuum. More vacuum means the slide moves higher, meaning a narrower bit of the needle is blocking the jet. So if the slide sticks higher up then the mixture will be FAR richer.
| sickpup |
 sickpup Old Timer
| D O G |
 D O G World Chat Champion
 Posted: 00:47 - 15 Dec 2008 Post subject: |
Since it was my thread to start with, I'll tell you what was acutally wrong with the bike (after much investigation, part changing etc). The fuel pump cutoff was dodgy, which meant that it kept pumping too much fuel in on low revs, but ran fine at high revs as the fuel was needed.
This caused #2 carb to be flooded all the time, as it is nearest the fuel inlet pipe. The problem became progressively worse until it wouldn't run at all at low revs, became impossible to start and it went to a garage and someone who knew what they were doing looked at it.
Think people (like me) like to blame carb icing, since it is one of those 'phenomenon' problems, which is an easy explanation for shit running, when in fact there is just something wrong with the setup or a faulty part in the bike.
I'll say this though, even after it was fixed and apparently setup on a rolling road it ran lumpy at low revs. My 91 FZR 600 pulls smoother than the SRAD ever did. I don't know whether this is a common problem with the bikes, or that the skills of setting up a carbed bike are dying. |
| ben_wheely |
 ben_wheely Trackday Trickster
| Kickstart |
 Posted: 14:52 - 15 Dec 2008 Post subject: |
Could just be that it is lean at idle. Carb icing is highly unlikely to be the cause if it happens from cold, as carb icing is caused by air / fuel taking the heat from the carb body, so that water condenses and freezes on the carb body. Hence it needs a bit of time at a fair speed before the problem will occur.
Would probably only take a couple of minutes of low speed riding / idling while blipping the throttle to clear the icing as well.
| NiteMare |
 NiteMare Spanner Monkey
| Drew |
 Drew Banned
 Posted: 18:42 - 15 Dec 2008 Post subject: |
| sickpup wrote: |
I hate it when it gets cold, every running problem gets put down to carb icing |
I wasn't saying it was carb icing, it was a question to weather it was or wasnt.
| Damofo D.O.G. wrote: | I'll tell you what was acutally wrong with the bike (after much investigation, part changing etc). The fuel pump cutoff was dodgy, which meant that it kept pumping too much fuel in on low revs, but ran fine at high revs as the fuel was needed. |
I can't have the same problem, as I had this problem around last Christmas, but not at all during this year, and it has just started again now.
So we conclude that it isn't carb icing, so what is the problem, or even more to the point, how can I fix the problem? What things can I try? |
| Drew |
 Drew Banned
| sickpup |
 sickpup Old Timer
| Drew |
 Drew Banned
| Kickstart |
The last post was made 17 years, 318 days ago. Instead of replying here, would creating a new thread be more useful? |
