Yamaha Sr125
tmsbird
PostPosted: 14:46 - 21 Dec 2008    Post subject: Yamaha Sr125 Reply with quote
Hi, guys wonder if you could help me please. I’m new to the forum.
I’m rebuilding an SR125 with the help of my twin boys. We dropped the engine out to clean it up. When we did it I forgot to unconnected the throttle cable from the top of the carb. I unscrewed the top of the carb and took out the spring, needle etc and put the engine on the bench. My problem now is the throttle cable has pulled up inside the top of the carb. I can’t get it out so I thought Id just buy a new one but I can’t find any second hand ones and even if I could what do I need to look for? Do I buy the twist grip assembly including the top of the carb? Or can I just replace the throttle cable? Can I cut the cable to get it out or should I carry on trying to force it through. Any Ideas gratefully received.
Rolling Eyes
PostPosted: 19:40 - 21 Dec 2008    Post subject: Reply with quote
It sounds like someone has just twisted the throttle.
Have you tried rolling the throttle back to the off position?
tmsbird
PostPosted: 09:47 - 22 Dec 2008    Post subject: Reply with quote
The nipple that goes round the needle piston thing!!in the top of the carb, had pulled up inside a plastic sleeve that presumably protects the cable. after lots of hours of swearing and hotwater I managed to get it pushed through. I seems ok! so panic over.
Thanks for the help. I'm sure I'll be back with more
Cheers Very Happy
The last post was made 17 years, 66 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.29 - MySQL Queries: 14 - Page Size: 34.98 Kb
