GS 500 fueling problem
veze
PostPosted: 17:42 - 21 Dec 2008    Post subject: GS 500 fueling problem Reply with quote
hi guys,
well, ive been having trouble with my gs,
the things is, its got plenty of fuel in and all that and it will run.
just not very well.
i bought the bike 6 months ago, it had onley done 18,000 miles, for a twenty year old bike it aint bad goin. it had been stood for a year so i cleaned the carbs, flushed the tank and put an inline filter from the fuel tap to the carbs.
the thing is that i would be riding normally then as if from no where the bike will bog down, it struggles to rev and eventualy cuts out. which is very dangerous when your on the m1 i can tell ya. it wasnt a good day out.
well, once this has occured, i would put the choke on and it will start, or sometimes struggle, ive also found that if if im trying to start it on the choke when this happens, if i opent the throttle the revs will drop even though the chokes on. so i got a used fuel tap from a local bike shop and put that on this morning, but it happend again, this time it just wouldnt start at all, not with choke, nothing, it wont bump, and the battery is now flat because of me trying to get it going. any suggestions very welcome
josh.
tlm50,mt5,sr50. rs125 extrema, cbr 400rr nc29 suzuki gs500e.Honda cbx250 rs . FJ1200 .fz6,fjr1300
veze
PostPosted: 20:51 - 21 Dec 2008    Post subject: Reply with quote
i also know that the plugs are firing ok aswell as it was running ok before it died. i think my timing mit be slightly out aswell, sometimes every now and again when i hit the starter the bike makes a big clunk, which sounds like its coming from the top end, but then starts. my dad reckons its backfireing through the valves. is that correct?
molex
PostPosted: 06:07 - 22 Dec 2008    Post subject: Reply with quote
you better ask them
https://www.gstwins.com/gsboard/
molex
PostPosted: 06:08 - 22 Dec 2008    Post subject: Reply with quote
you better ask them
hmmmnz
PostPosted: 06:50 - 22 Dec 2008    Post subject: Reply with quote
chuck it on prime and gofor a ride, (don't leave it on prime when you stop, hydrolocking is also common)
its a common problem on the gs500
set the carbs and needle height back to standard and try again
the humans are dead
I kick arse for the lord
PostPosted: 09:57 - 22 Dec 2008    Post subject: Reply with quote
I had this problem with mine too, setting it to prime "fixed" it
The last post was made 17 years, 69 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.26 Sec - Server Load: 2.5 - MySQL Queries: 14 - Page Size: 48.41 Kb
