Q Plate??
Demonic69
The Pink Rhino
PostPosted: 18:44 - 13 May 2003    Post subject: Q Plate?? Reply with quote
If I stuck a Gixxer1100 Engine in my frame would I need a Q plate?
Cheers Dean
Back on a Blade. Just feels so right.
TiN
Pocket Tin
PostPosted: 18:46 - 13 May 2003    Post subject: Reply with quote
Your log book is primarily concerned with your frame/chassis number, so the answer is "no". My engine number is ommited from my V5.
TiN
dotgems.net
PostPosted: 19:03 - 13 May 2003    Post subject: Reply with quote
No you would not need a Q plate (and you really dont want one). Q is query as to the age, and is basically chassis related. You might get hit for it if you had tried registering it originally with the 750 chassis and an 1100 engine.
By the way a GSXR1100 engine will not be that cheap. Basically the same engine as the 1200 Bandit and the best deal I got for a 2nd hand one was £650, but that is without the carbs, alternator or starter motor
kev
I Hump Things
PostPosted: 20:56 - 13 May 2003    Post subject: Reply with quote
i know sombody with a load of bandit bits including carbs and a jet kit
20:02:36 Jammy-R6: any holes a goal
20:02:48 kev: even if its a hairy mans arse
20:02:56 Jammy-R6: hell yes
PostPosted: 23:26 - 13 May 2003    Post subject: Reply with quote
He wouldnt have a decent cylinder head with valves, or a set of barrels with pistons would he?
kev
I Hump Things
PostPosted: 08:18 - 14 May 2003    Post subject: Reply with quote
i will get a list of the stuff hes got
Demonic69
The Pink Rhino
PostPosted: 10:33 - 14 May 2003    Post subject: Reply with quote
How much of the bits I'd need could I pillage off mine?
PostPosted: 13:50 - 14 May 2003    Post subject: Reply with quote
Think you will need the carbs, starter and alternator and almost definatly the cdi unit as well as the engine. Exhausts will probably be needed, but not sure, same for oil cooler.
The last post was made 23 years, 155 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.46 - MySQL Queries: 14 - Page Size: 56.44 Kb
