Basics stuff to check when buying a bike...
PostPosted: 01:57 - 18 May 2003    Post subject: Basics stuff to check when buying a bike... Reply with quote
Seeing as the question pops up quite a lot, thought it would be worth listing it in a FAQ...
Can't be bothered to do anything now 'cos I need to go to bed Smile ...
Feel free to add your own thoughts Smile
PostPosted: 02:10 - 18 May 2003    Post subject: Reply with quote
Points to check
Body Work – Check it for damage, or damage repair
Tyres – How much tread is left? A new set of tyres can cost upto and around £200
Exhaust – Does it have a race can fitted? If so, does it have the original can with it? You will need this for MOT’s, and it asks the question has the bike been crashed, as race cans are cheaper than originals.
Chains and sprockets – Check for wear on them, ask how long ago they were replace. How much wear/ stretch is left in the chain. Check this by looking at the chain adjusters.
Wheel Bearings – Check this by lifting the bike off the ground (either with a paddock stand, or with help from someone) and check for sideways movement in the wheels. If there is, this shows worn bearings, which will need to be replaced
Head Bearings – Try and turn the bars whilst holding the wheel between your legs. Is there any place? If so, bearings will also need replacing.
Electrical – Try all lights, indicators, warning lights, cut off switches, brake lights, and anything else there might be. It should all work correctly. If not, check fuses and bulbs. Otherwise the problem could be deeper within the wiring which could be time consuming to find.
Forks – Check to see if they are smoothly moving down when leaning on the front of the bike. See if there is oil going down the fork legs, which suggests leaking seals.
Rear suspension – Bounce on the back of the bike, checking for smooth movement, and any clicks.
Frame – Check that it is free from dents, large marks, and that it looks straight. A bent frame should become obvious on a test ride. If the frame has been polished, ask why. Look for any damage repair work.
Wheels – Check rims for chips and scratches, as this indicates lots of mileage, as lots of tyre changes. Or it could have been a race bike.
Body Work – Is it very clean or tidy for a bike of this mileage and condition? If so, it could have been recently/ just replaced, to repair an accident, or it has been used as a track bike.
Foot Pegs – Have these been ground lots by the owner doing knee down? Also they will grind if it has been crashed.
Sump Plug: Has it been drilled? If so, it has been used for racing. Does it look shiny and new, and out of style with the rest of the bike. If so, it has just been replaced, possibly to hide the fact it has been drilled.
Oil – Look into the view hole, and see if it is at the correct level. Also check to see for leaks under the bike where it has been kept garaged.
Engine – Start the bike from cold. If they have warmed it up before you arrive, allow it to cool down, so you can see if starts correctly from cold. Check how long it takes to start, and if it starts again easily once warm.
Radiator – Check for chips, and repairs or damage. Repairs and replacements can be expensive.
Spare Parts – What spares does it come with, and why does it have these spares? If it has any aftermarket parts, ask for the originals to go with it.
Test Ride – Take the bike out on a ride. It is normal to be asked to leave money with the owner when you do this. Try and test it as completely as you can.
Take a Friend – Take someone with you who knows about checking bikes over, and will stop you if it is obviously a bad buy!
General Stuff
- Make sure you look into insurance before purchasing the bike. Just because the seller tells you that its cheap to insure doesn’t mean that it is. Looks at the insurance thread in this forum, or use the search function.
- Make sure that you get the V5, and all the paperwork to go with the bike. Receipts for any work that has been done helps to build a complete history.
- How much Road Tax, and MOT has it got left on it? If it’s not much, ask them if they can get them updated, and get it MOT’ed
- Haggle the price down. Most bikes are advertised for about 10% than they expect to get for it.
- Ring up previous owners if your not sure about something they say. A genuine seller will not mind giving you information about the bike and its history.
- Are you licensed to ride it? Is it learner legal, and can you get a 33bhp kit for it if you need/ want to fit one?
- Get the bike HPI checked, to see if it has been an insurance write off, it’s it stolen, and if it has any out standing finance on it. If so, do not buy it until it is HPI cleared
- Ask them why they are selling it? Find out if they actually know about the bike if it is a private seller. Genuine sellers will be happy to talk all day long about their bike
- Kit with the bike? Are they including anything with the bike? Helemts are no good second hand as you do not know if it has been dropped. Leathers and clothing needs to fit you, not them. It is not of much value to you, so don't be told "this kit is worth £xxx in the shops!" as it is worth a fraction of that unless you are thier identical twin
- Security? Does it have an alarm, immobiliser, or anything like that? If so, has it been fitted by an insurance approved workshop? Does it have the paperwork to say so? Make sure you get all the paperwork for things like DataTag, or AlphaDot.
- Where has it been stored? In a garage? Outside? Find out, as a bike which has been sat out in all weathers will be worn for it.
Further Reading
- [url= https://www.motorcyclenews.com/advice?sectionID=0&navID=81
MCN[/url]
- Used Motorcycle Evaluation Guide
- The search function!
If your not sure about a bike, leave it. It’s best to look back and think “Oh, it was a good buy after all” rather than to have spent a large amount of cash on a bike that is not working, or is dodgy.
Hope this is of some help Smile
TiN
Pocket Tin
PostPosted: 12:05 - 18 May 2003    Post subject: Reply with quote
Ok, just to attempt to build upon Ste's list, and possibly explain how everything should affect your decision:
Also check for mis-matched/mis-aligned panels, and whether they are original plastics or aftermarket fibreglass etc. Unless the seller has already made a point of this, expect the value of the bike to drop by around £500 (for a fully faired bike).
Another thing to look out for is a paintjob - some people get them done for innocent reasons, whereas others get them to cover up crash damage.
Also check the condition of the downpipes and collector pipe(s). If they're ready to rust through, then expect to get replacement pipes soon.
New race cans are often cheaper than new standard cans from the manufacturer, but check out private ads/breakers/ebay for fairly cheap replacements.
Also have an assessment of the actual condition of the chain...is it clean and well lubed/waxed? If the owner can't even be bothered to take care of the chain, what does that say about the rest of the bike?
You can basically use this to knock the price down a bit, but it could also deter you to ride the bike home.
Don't forget the horn. If it's a Honda then ask if the Regulator/Rectifier has ever needed replacing. Ask if it's an import - if it's a grey import, then it may have a restricted speedo/CDI. There's stuff about headlight alignment that you could ask about, but you probably won't be able to check yourself.
Older/higher mileage bikes would probably have had the rear shock replaced, which would be fair enough, but obviously make sure that you get receipts to prove this.
Don't complain if it has an Ohlins, but bear in mind why the owner needed to get a high performance shock...
Don't forget to take a peek at the frame numbers.
Also check for aftermarket rearsets. They are usually a good thing but if they're non-adjustable then make sure that the new seating position is suitable for you. Some people get rearsets to replace damaged original footrests, some sell undamaged footrests, some keep them.
Check when the oil and filter was last changed. It is usually recommended to change the oil every 8000 miles/12 months, and dirty oil is usually detectable through a clunky gearbox.
Don't allow the seller to make you think that the bike is worth more because of the spares. Some people like to return the bike to standard before selling, whereas others would rather sell everything in one go. If the seller is the latter then make them think that you're them a favour by taking the extras with you.
Additional stuff:
Brakes - check the condition of the pads, calipers, and discs. You can tell if the disc is warped either by spinning the wheel (on a paddock stand obviously), or going on a test ride - the brakes should feel bumpy. If the bike is old/high mileage then the calipers will probably be full of crud, so they'll probably need stripping down and servicing.
Bolts + loose bits - look around for missing bolts or bits of wire dangling around the bike.
TiN
dotgems.net
TJ NSR
PostPosted: 22:03 - 24 May 2003    Post subject: Reply with quote
check the milages on the service book and mot, se if they match at the correct times....!
PostPosted: 22:19 - 24 May 2003    Post subject: Reply with quote
Amd just the MOT certs... my first bike (cg) I got the MOT certs but never checked 'em out... it had lower in one than the previous one!
And that was from a dealer!
Never got round to making a fuss, because it would have probably been more hassle for me (and lazyness Smile )
JimboJ
Manc Pikey
PostPosted: 17:28 - 04 Jun 2003    Post subject: Reply with quote
I'm not sure if this was mentioned but:
When buying a bike never be over keen to the seller (be as keen as you want to your friends) simply because he is less likely to knock any money off it if you are stood there writing out a cheque before you buy it.
Seem a little unimpressed, tell the seller of other bikes you have been to see purely so he doesn't think he has you hook, line and sinker.
Never got to a buyer with your wallet open with wads of cash in wafting it in his face.
Never commit over the phone and under no circumstances do you ever tell the buyer how much you have to spend, because in most cases he will not drop below that.
[00:42] <NSR-Andy> which one's the missionary position
[00:42] <NSR-Andy> i've heard it's good
[9:42pm] <Shaun> you came first mike | <Shaun> yes gav, because I really want to fuck you
Danny
Ask Me About Stoppie School
PostPosted: 17:33 - 04 Jun 2003    Post subject: Reply with quote
Actually this can help, say he is adamant he won't go bellow £2500, waft £2000 in his face and he might change his mind
There is a gap of 193 days between these two posts...
NSR125-Kid-UK
Attention Whore
PostPosted: 04:26 - 15 Dec 2003    Post subject: Reply with quote
Interesting thought there Danny Razz .
https://www.bikepics.com/members/nsrandy/96rs250/ My Bike!
"I'm either going to teach andy to get his knee down, or I'm going to get him killed. One of the two" - Teaman
divuk83
PostPosted: 11:45 - 20 Dec 2003    Post subject: Reply with quote
carrying on from the whole footpegs things, the end of break/clutch levers are worth looking at as if there scratched then its been dropped/crashed. as well as non standard indicators, eg aftermarket stalk ones means the same as they are often cheaper than original ones, and the same can apply to mirrors too.
also watch for stickers etc as they can be used to hide damage and scratches.
NSR125-Kid-UK
Attention Whore
PostPosted: 05:31 - 22 Dec 2003    Post subject: Reply with quote
I read through this post, and i've prepared this to make going over a potential bike easier for buyers. It's probably not perfect, but tell me what you think Smile .
gtechosting
PostPosted: 22:06 - 02 Jul 2004    Post subject: Reply with quote
Well this is great, thanks guys (although half of it went over my head) im sure i will get a better deal Wink
map
Mr Calendar
PostPosted: 15:15 - 28 Jul 2004    Post subject: Reply with quote
Created a little table of registration years as it always confused me looking through adverts, calling dealers etc. to tie registration in with year.
Thought it may help other so uploaded here Smile
mamak
PostPosted: 15:07 - 01 Sep 2004    Post subject: Used Motorcycle Evaluation Guide Reply with quote
Check out the following https://www.clarity.net/adam/buying-bike.html . This is a comprehensive guide that makes a newbie seem like an experienced biker to the seller. Thumbs Up
paulodd
PostPosted: 00:06 - 02 Jan 2005    Post subject: Reply with quote
https://www.motobykz.co.uk/UsedMotorcycleGuide/UsedPriceGuide.htm
Paul
1999 Yamaha R6
www.coventrybikers.co.uk / www.norfolkriders.co.uk
There is a gap of 2 years, 161 days between these two posts...
veeeffarr
PostPosted: 20:16 - 12 Jun 2007    Post subject: Reply with quote
Back to the top, for summer Thumbs Up
pwntifex
PostPosted: 20:31 - 12 Jun 2007    Post subject: Reply with quote
Why is this not stickied?
GodzGift
PostPosted: 10:23 - 02 Jul 2007    Post subject: Reply with quote
+1 Thumbs Up
Bike Level: Amateur | CBT Passed
Jamie S
PostPosted: 13:47 - 02 Jul 2007    Post subject: Reply with quote
+2.
Very good post ste.
Thumbs Up Thumbs Up
The last post was made 19 years, 99 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.51 - MySQL Queries: 13 - Page Size: 113.06 Kb
