Brakes
c-m
PostPosted: 00:59 - 24 Jan 2009    Post subject: Brakes Reply with quote
I seem to have noticed more recently that the front brake on my zxr750 bites ok initially but then seems to fade a little as the braking continues.
Is this normal? I've only had bikes which barely stop before i.e GPZ.
I would like something with a good even bite throughout the braking process.
Motorcycle headlight bulbs and HIDs
Blogging about my bike and trips
https://ridershandbook.com/
Itchy
PostPosted: 01:16 - 24 Jan 2009    Post subject: Reply with quote
your brake fluid heating up too rapidly?
TheDonUK
PostPosted: 01:42 - 24 Jan 2009    Post subject: Reply with quote
Rubber hoses on the way out?
6-Pots? Do with a good clean?
PostPosted: 01:55 - 24 Jan 2009    Post subject: Reply with quote
Sounds like a post for the Workshop
binge
Emo Kiddy
PostPosted: 02:22 - 24 Jan 2009    Post subject: Reply with quote
Sounds like it could do with some new brake hoses if you havnt got braided lines already.
Again, If the Fluid is old, it could be heating up and causing loss of pressure.
Does sound like the hoses though, My mates gixxer 6 has the same problem, And its got a set of 15 year old rubber hoses on it. Laughing
neatbik
PostPosted: 09:15 - 24 Jan 2009    Post subject: Reply with quote
Yep, as said it sounds like your rubber hoses need replacing.
Fit some braided lines and change the fluid. Thumbs Up
Skudd
PostPosted: 09:40 - 24 Jan 2009    Post subject: Reply with quote
I would first of all bleed the brakes,
If that doesn't work change the fluid
If that doesn't work then think about the hoses.
Keep it simple.
Little tip, tie your brake leaver as far back to the bars as you can over night, this should push any air out of the banjo bolts and little pockets in the system. Your brakes will feel alot sharper.
The last post was made 17 years, 277 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.65 - MySQL Queries: 14 - Page Size: 53.06 Kb
