Taper rolling headstock bearings
Bikeless
PostPosted: 14:15 - 25 Jan 2009    Post subject: Taper rolling headstock bearings Reply with quote
Hi,
I am currently using standard headstock bearings in an early Fireblade,they will need doing this year and i was wondering if there is any benefit from converting to taper rolling ones?
When i adjust the original ones they never feel tight even when new.
Thanks,Paul.
PostPosted: 14:45 - 25 Jan 2009    Post subject: Reply with quote
Yes, taper roller bearing are far superior to rollerball bearings. The contact-patch is larger so they don't make dents in the races so easily from being in the same position most of the time.
sickpup
Old Timer
PostPosted: 17:53 - 25 Jan 2009    Post subject: Reply with quote
But have the disadvantage that as they have a bigger contact area they 'can' make the steering feel a little heavier. As the bearings aren't themselves tapered they also tend to slide as well as roll but this is minimal over the swept use area.
I still fit them and recommend them over ball bearings.
Bikeless
PostPosted: 17:43 - 26 Jan 2009    Post subject: Reply with quote
I'll give them a whirl then,come changing time.
Cheers.
The last post was made 17 years, 16 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 1.72 - MySQL Queries: 14 - Page Size: 39.32 Kb
