| funmonkee |
 funmonkee Super Spammer
 Posted: 15:49 - 04 Feb 2009 Post subject: So, What's the success rate of |
removing snapped front disc bolt from a wheel. The wheel I snapped the head off the disc bolt is a 99 Vmax. Luckily, It's one of my spare wheels
Took the wheel to the local tech shop and asked them... they said pretty much impossible, but were willing to give it a try.
I've never had any luck with bolt extractor kits; they all seem to snap before the actual bolt is removed.
What's your mileage been for this type of job  ____________________ **** Don't ride faster than your angel can fly Get this Free Space
The democratically elected Mod of the Scottish Section - The Peoples Choice[b] |
| tafflade |
 tafflade Nitrous Nuisance
 Posted: 16:01 - 04 Feb 2009 Post subject: |
100% for removing exhaust studs in the same situation, well, actually when I say 100% I mean that it worked both times that I tried it.
I used 2 nuts to lock together on the thread that was left, a blowtorch and a lump hammer to provide some shock on to the end of the stud then unscrewed very gingerly praying that it didn't shear again.
good luck  |
| BanditsHigh |
 BanditsHigh Worse than a woman
| funmonkee |
 Posted: 16:11 - 04 Feb 2009 Post subject: |
Hmmm yes, I knew it was possible. Maybe the tech guys are going to charge me big time for the pleasure
The disc bolt is snapped half way down the shaft, which is lower than the facee of the hold; therefore it's inside the wheel. So I can't get extra nuts on it
Barry I'd happily bring the paddock standards down to yours (I take it it's for changing tyres?) If you can get the bolt out. We'll see how they get on... If they do manage I'll plan on visiting you anyway
PS I snapped it with my good arm It looked okay when I started... ____________________ **** Don't ride faster than your angel can fly Get this Free Space
| SoND |
 SoND World Chat Champion
| loply |
 loply World Chat Champion
 Posted: 17:55 - 04 Feb 2009 Post subject: |
How much useable thread is left in the hole in question?
If it's more than 3/4mm I would suggest simply cutting the new bolt down to a length that fits, and loctiting it in with a strong compound.
Yada yada yada, I know lots of people will belch at this, but the plain fact is that it ain't going anywhere. Even without the loctite it wouldn't budge, let alone if you gum it up with 648 or somesuch.
If you DO want to remove it, my recommended technique would be to somehow drill a drillbit into the remaining bolt, then, carefully coat the said drillbit in Loctite 648 and twist it back into the bolt... Leave it to set, then twist it out. Hopefully the Loctite grips strong enough that the drill bit unscrews the bolt.
Prior to this I would heat the bolt in question heavily then whack it downwards with a centrepunch type device to shock it from the thread. ____________________ Yamaha SZR660 Caution to the wind, the throttle pinned! |
| BanditsHigh |
| Blue_SV650S |
 Blue_SV650S World Chat Champion
| funmonkee |
| hmmmnz |
 hmmmnz Super Spammer
| funmonkee |
| GSXFire |
 GSXFire Trackday Trickster
 Posted: 20:40 - 06 Feb 2009 Post subject: |
Pentland at the back of IKEA in Edinburgh got the studs spark eroded out of my Bandit head, they taped the threads and fitted Helicoils where needed and then put new bolts in. top job done in a week. ____________________ Fire by name Firefighter by nature.
My old bikes. https://www.bikepics.com/members/firefighter1/ |
The last post was made 17 years, 258 days ago. Instead of replying here, would creating a new thread be more useful? |
