| monkeyboy111 |
 monkeyboy111 Borekit Bruiser
| virus |
 virus World Chat Champion
 Posted: 14:03 - 26 Feb 2009 Post subject: |
Remove the rocker arm that the thread is stuck in, take it to an engineering shop and get them to remove it, then get a new bolt in there.
John ____________________ own: 81 xs1100g...
stinkwheel Well I just had my hands up a pigs fanny. Which makes your concerns pale into insignificance. |
| Knacker |
 Knacker World Chat Champion
 Posted: 14:04 - 26 Feb 2009 Post subject: |
Was probably Torqued down to much or Faulty bolt
Best way to remove it is to take the head off which will leav enough to get hold of to remove  ____________________ Current: Gsxr 600 Srad - GS125 - DT125
Previous: K1 GSXR 1000 |
| inchi55 |
 inchi55 Two Stroke Sniffer
| Darth |
 Darth World Chat Champion
 Posted: 20:27 - 26 Feb 2009 Post subject: |
Buy a new camera for a start!
Have used these with great success before on sheared exhaust manifold studs-
Blue point Screw extractor set
Sold my set a while back, think i paid about £60 for them which aint cheap but they were the shizzle! |
| ZaphodBeeble |
 ZaphodBeeble World Chat Champion
 Posted: 20:36 - 26 Feb 2009 Post subject: |
Get a 4mm reverse drill bit and drill the centre of the bolt that's stuck. It might just spin it out. If it doesn't then stick a screw extractor in the hole you drilled. ____________________ Current bike: VTR1000F Firestorm. Previous: Firestorm (written off) - XJ600 Divvy - NSR125 - DT125 and a load of offroaders. |
| Pete. |
 Pete. Super Spammer
 Posted: 20:41 - 26 Feb 2009 Post subject: |
Superdream?
In any case first get a new rocker-cover bolt. Then try to pick the broken bit out carefully. If you can't get it out, remove the rocker carrier from the head and drill the bugger out. I can't recall if that is threaded right through, but if it is just use a 3.5 or 4mm bit and drill from below, it should wind the bolt out no problem. Don't run the bike with the broken bit in there coz if it winds down onto the can it might ruin it. Looks like an easy repair I reckon I could get that out no problem. ____________________ a.k.a 'Geri'
The last post was made 17 years, 214 days ago. Instead of replying here, would creating a new thread be more useful? |
