what reasons for carb leak?
steppen22
PostPosted: 23:21 - 04 Mar 2009    Post subject: what reasons for carb leak? Reply with quote
I wondered what are the common reasons for carb leaking/weeping?
I got out the scootay today, and it stunk of petrol. I noticed that the carb is leeaking, from the breather tube. What are the causes to investigate? Damaged needle? Float bowl? I hoped instant gasket would save me. Alas, no. I'd rather fix than replace, as I hardly use the scootay.
Please advise.
Cheers.
https://img10.imageshack.us/img10/2195/carb.jpg
no regrets, no retreat, no apology.
I've made mistakes in the past, and I apologise for FUCK ALL.
KevTM
PostPosted: 23:30 - 04 Mar 2009    Post subject: Reply with quote
Is that a breather or an overflow? could just be a stuck float perhaps. If it's leaking from the pipe why instant gasket around the float bowl face? unless you know the proper seal isn't in there (o-ring maybe.. which would cause petrol t leak through into that pipe i would have thought)..
whip it off and find out Thumbs Up
The Artist
PostPosted: 00:19 - 05 Mar 2009    Post subject: Reply with quote
that carb needs an outside clean aswell as an inside one.
Usually, float gets stuck down so when bowl fills with fuel, it keeps pouring in, overflows and pours out into air box/breather/engine.
Could be other things though, although that is your best bet, try tapping the float bowl to loosen up float or for permanent fix, remove carb, undo the 4 screws on teh float bowl and clean out with carb cleaner or similar.
S1KE
PostPosted: 09:07 - 05 Mar 2009    Post subject: Reply with quote
Could be the needle valves need replacing as they are not shutting off properly, I had to do it on the zxr, cost me like 80 quid for a set Thumbs Up
random twat!
* xbox live mickeyc26
* zx6r b1h 2004 GREEN !
The last post was made 17 years, 188 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.48 - MySQL Queries: 14 - Page Size: 40.15 Kb
