| warped one |
 warped one Banned
| SoND |
 SoND World Chat Champion
 Posted: 02:41 - 09 Mar 2009 Post subject: |
Why are you trying to create backpressure? ____________________ Go back to bed - You have no rights - "Streetfighters ~ Mainstream motorcycling's crackwhore sister." |
| MaybeGuy |
 MaybeGuy Super Spammer
| s44678 |
 s44678 Guest
| Kickstart |
 Kickstart The Oracle
| Cigaro |
 Cigaro World Chat Champion
| proximity |
 proximity Crazy Courier
| MaybeGuy |
 Posted: 13:35 - 09 Mar 2009 Post subject: |
oh right, i thought he meant a whole system. ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
| Kickstart |
| warped one |
 warped one Banned
| Kickstart |
 Posted: 18:40 - 09 Mar 2009 Post subject: |
I would just go for a basic setup. Cap on each end with a perforated tube between then. Match the size of the holes in each cap to your existing pipe and to the perforated tube. Wrap sound absorbing material tightly around the tube when you assemble it, and taking up the space between the perforated tube and the outer tube.
For real cheapness use loft insulation, but don't expect it to last that long. You can buy baffle packing material fairly cheaply (try a local motocross shop).
| warped one |
 warped one Banned
| Kickstart |
 Posted: 19:35 - 09 Mar 2009 Post subject: |
Yep. The packing will compress and loose effectiveness over time but if you make it bolt together you can repack it easily (the old Allspeed 2 stroke exhausts held the baffle in with a large circlip which made repacking them a doddle).
Presume you will make up a pipe for it to slip on to the rest of the system with and tart up the outlet a bit.
| proximity |
 Posted: 19:45 - 09 Mar 2009 Post subject: |
I had a can with rusted end caps and the idea went through my head of buying endcaps to make exhausts. I know you can buy them because i've seen them on ebay. Im wondering if any manufacturers do them as spares, but saying that they wont be cheap.
edit: found this:
https://www.pjengineering.co.uk/products.asp?cat=10 ____________________ 2004 Aprilia Tuono |
| warped one |
 warped one Banned
 Posted: 23:00 - 09 Mar 2009 Post subject: |
Cheers for the help, guy's to you all.
I was thinking of using St/St swarf, for the packing as the is an abundance around the corner from my workshop, would it be ok to use this?
And would using this method mean that I would have to rejet? Or would it belike using my stock exhaust but with a deeper note?
And I was thinking that when the packing does become compressed and a bit shagged i'd just make another one, as the longest part so far is waiting for the old man to bring me home a 52mm hole saw.
But I do have a couple of CAD designs that are for a full system that would eliminate the dog poo curl from the back cylinder and bring it out the back of the fairing with 2 exit pipes. So thus bringing up another question of is there an optimal shape and size that I could fit in my fairing? Paint pics to follow.
Warped
Warped ____________________ amnesia - Never in the history of usernames has one been more accurate. Warped indeed. You sir are a fecking oddball. |
| Kickstart |
 Posted: 23:16 - 09 Mar 2009 Post subject: |
I know that some exhaust makers have used stainless steel wool as baffle packing (being long lasting), but no idea how effective it really is. Real small bits of swarf would be useless as they would just fall through the holes in the perforated tube.
There is a fair chance that whatever you do will mean having a play with jetting. You will change the flow of gases, but whether by enough to have enough affect that you care is another question.
| proximity |
| warped one |
 warped one Banned
| Kickstart |
| chris-red |
| warped one |
 warped one Banned
| warped one |
 warped one Banned
| Kickstart |
| SoND |
| Rottweiler |
 Rottweiler Scooby Slapper
The last post was made 17 years, 221 days ago. Instead of replying here, would creating a new thread be more useful? |
