Are two stroke and Four stroke carbs diffirent?
Jamie S
PostPosted: 22:00 - 19 Apr 2009    Post subject: Are two stroke and Four stroke carbs diffirent? Reply with quote
Any one know ?
PostPosted: 22:09 - 19 Apr 2009    Post subject: Reply with quote
Believe there are differences in the style of atomiser nozzle used. Not sure of what other things are changed (beyond a carb for a 2 stroke possibly having a connection point for a 2 stroke oil feed pipe).
chaz e z
PostPosted: 23:19 - 19 Apr 2009    Post subject: Reply with quote
They are different, iv owned a 4 stroke in the past and there are a few differences. Four stroke carbs have the throttle cable on the side, bigger main jet and a plastic diaphram which uses compression to move the needle. Were as a 2 stroke has the throttle cable on top, smaller main jets and throttle cable moves the needle. I am on basing this on the carbs i have worked with.
Peugeot Speedfight 100cc (Fully tuned but confused!)
Vespa PK 135 (Fully tuned)
18 and live in Hull
sickpup
Old Timer
PostPosted: 23:30 - 19 Apr 2009    Post subject: Reply with quote
Sort of.
Very few 2 strokes use CV carbs as the intake pressure isn't as low so less vacuum to open them. Other than that most 2 stroke carbs are pretty much like flat slides, the throttle cable is connected directly to the slide not to a butterfly as on a CV carb.
PostPosted: 11:46 - 20 Apr 2009    Post subject: Reply with quote
That is the difference between CV carbs and slide carbs. Plenty of 4 strokes use slide carbs.
Barry_M2
PostPosted: 11:59 - 20 Apr 2009    Post subject: Re: Are two stroke and Four stroke carbs diffirent? Reply with quote
jamie stokes wrote:
Any one know ?
Why do you ask?
Are you planning on fitting different carbs to a bike?
ZXR750R (M2) - For the road.
CBR1000 RR4 - For the track.
The Artist
PostPosted: 13:40 - 20 Apr 2009    Post subject: Reply with quote
Premix 2 atroke carbs will have a bigger main jet to cope with the extra viscosity of the fuel/oil mix.
dougon2wheels
PostPosted: 17:10 - 20 Apr 2009    Post subject: Reply with quote
kickstarts right,this tends to be almost the only difference between the same carb used on a stroker and a 4t
KevTM
PostPosted: 18:56 - 20 Apr 2009    Post subject: Reply with quote
Am I right in saying 2-stroke carbs have an Air pilot screw and 4-stroke carbs use a Fuel pilot screw.. something to do with vacuum or the likes?
binge
Emo Kiddy
PostPosted: 21:01 - 20 Apr 2009    Post subject: Reply with quote
My Pit bike is a 150cc 4 stroke single. It uses a VM24 Mikuni Slide carb. It has an Air Pilot/bypass screw. Screw it in to Richen the mixture, Out to Lean it out.
My old scooter was a speedfight, 70cc. It was running a 19mm Delorto slide carb. And I believe that had an air pilot/bypass screw too. In for Rich, And out for lean.
Ben
chaz e z
PostPosted: 21:09 - 20 Apr 2009    Post subject: Reply with quote
Thanks, i did not know, that was the difference i saw with the carbs iv worked with
Thanks
18 and live in Hull
PostPosted: 21:09 - 21 Apr 2009    Post subject: Reply with quote
Seen both used on 2 strokes.
80sbiker
PostPosted: 02:45 - 22 Apr 2009    Post subject: Reply with quote
In general 2t carbs have the mixture screw on the air box side of the carb and 4t carbs have it on the engine inlet side, can be either cv, flatslide or normal round slide type.
Very Happy
The last post was made 17 years, 157 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 1.06 - MySQL Queries: 13 - Page Size: 79.14 Kb
