Bike to bike intercom
Bike Chat Forums Index -> Touring & Exploration Goto page 1, 2  Next
JonT
PostPosted: 21:51 - 26 Apr 2009    Post subject: Bike to bike intercom Reply with quote
Hey Guys,
I know there are a bunch of threads on this but none of the suggestions really meet my (our) needs.
We don't really have £300 to spend on bike to bike intercom and I don't see why they have to be so expensive.
So I was wondering if anyone had tried a cheaper solution that has worked well or perhaps a bodged solution out of other parts that works.
I was thinking something along the lines of a normal cheap walkie talkie. One that has 3.5mm sockets for microphone and a headphones. A throat mic could be used for the microphone (so should work at speed) and any old ear phones to listen.
ajb
PostPosted: 21:56 - 26 Apr 2009    Post subject: Reply with quote
I got the Lidl ones, they were OK walkie-talkies, but sat on the bike at traffic lights neither of us could understand what we were saying, but we could hear the confirmation beep, at 50+mph, couldn't even here the beep. All in all, they were next to useless.
CBR125R '05 > CB500 '00 > CBR600F '99
Phoenix
Twisted Firestarter
PostPosted: 01:02 - 27 Apr 2009    Post subject: Reply with quote
Heard the same about the Aldi ones. Possibility I will be using a set later this year, if I do I will probably get a half decent set of walkie talkies with remote push button activation (or build it in myself) and then a decent motorcycle headset to go with it. VOX never seems to work right especially with wind noise, but the delay is the usual problem when it cuts off the first few seconds of everything you say.
njd27
PostPosted: 15:45 - 27 Apr 2009    Post subject: Re: Bike to bike intercom Reply with quote
We went touring last year with a set of Midland G7s and a couple of these:
https://www.maplin.co.uk/Module.aspx?ModuleNo=27212&TabID=1&C=SO&U=strat15&doy=search
The speakers and microphone glue into the helmet. I stuck the radio into the top pocket of my jacket. Then you have a PTT button for the handlebars which to be honest was a bit annoying but usable.
It worked fine: generally you only want to chat about petrol stops, etc: it's utterly useless if someone gets lost because as soon as they are out of eyesight radio reception drops but there's always text messages for that.
One of our headsets died: I think one of the cables came loose and it jammed on continuous transmit.
Not a bad solution for 140 quid.
Rob
PostPosted: 15:54 - 27 Apr 2009    Post subject: Reply with quote
Two cups and a long piece of string??!! Razz Laughing
Seriously though, the problem with the cheaper ones is that at anything above a crawling speed the sound quality just isn't good enough so you don't end up using them so you waste the money you did spend on them.
There is no doubt that if you want to go down the radio route then an Autocom is the best quality you can get, the problem (beside the cost) is that you still have a wire going to your helmet, you need to wire it all in to the electrics and it's generally a bit of a pain in the arse. If you are willing to spend the time (and have the space for it all) then there is no doubt it's the best option.
I now use a Scala Rider Q2 which is a fantastic option. It's easy to install. Works over an OK distance, lasts all day (but will need recharging after a day out) and works with phone/music/bike to bike. It's not cheap, but not as much as you would spend on an Autocom, but REALLY worth the money Thumbs Up
Love is 1050cc Smile
Wozza
PostPosted: 17:13 - 27 Apr 2009    Post subject: Reply with quote
I'll tell you what didn't work for me:
Midland GTX450 (which are actually good radios for general out and about) + £16 motorcycle headset on ebay.
From what I've read it does seem to be a case of spending lots of money or not bothering at all. I think I'll do the latter.
ajb
PostPosted: 18:04 - 27 Apr 2009    Post subject: Reply with quote
I've been looking around too, and the Cardo Scala Q2 does look like *the* best option, even better for £119.99 a pop (or twin-pack for £217.99).
My only thoughts on it are, how good is the attachment? seems like the entire gizmo is connected to the helmet, liable to blow away?
h00dwink
PostPosted: 23:52 - 27 Apr 2009    Post subject: Reply with quote
In short- there's no point getting them
Long-
Honestly I would say for the cost they're not worth it. Last year me and my friend Martyn (also on here) bought a relatively decent set for £100. Got in to France, set them up, joined some A road. After about 5-10 minutes we pulled over and decided to take them off as you couldn't hear a thing apart from wind blast above 30.
They had a push to talk button you could put somewhere, we put ours on the left grip as it was the easiest place. Awful though, got in the way of your hand and totally ruined your sense of control.
We're going away to the Nurburgring next month and aren't going to bother. There's nothing to talk about when riding really that can't be expressed just as well with hand signals.
point at tank= need petrol
point at a service station sign= pull in there when we come to turn off
point at something you've seen= hey look at that, it's interesting
really these are all you need, depending on what bike you're riding you can do roughly 100 miles to a tank abroad before filling up becomes a necessity as they're relatively few and far between.
Sahf East Winnah 4LYF
https://bikepics.com/members/h00dwink/00sv650s/
www.youtube.com/h00dwink updated regularly
Itchy
PostPosted: 00:14 - 28 Apr 2009    Post subject: Reply with quote
Meh things specifically designed for bikes are particularly expensive on purpose.
Take for example the Hein Gericke water proof bags , HG sells them for £40 for the 34 litre version , however a local camping store sells Gelert kayaking bags for £9 42 litres.
Either buy CB radios (which are shoe box sized but can be gotten off ebay for £30 and require a large aeriel attached to the back of the bike like cop bikes) and run them off 12volts, or don't bother.
Dagon
PostPosted: 10:26 - 28 Apr 2009    Post subject: Reply with quote
I just forked out for the twin pack and in all the reviews I've read it was never mentioned as a concern.
truslack
PostPosted: 12:54 - 28 Apr 2009    Post subject: Reply with quote
In the tank bag:
https://i177.photobucket.com/albums/w215/impreza_2007/photo-44.jpg
And you can make out the top of the aerial in this photo...
https://i177.photobucket.com/albums/w215/impreza_2007/photo-43.jpg
(yeah okay, I was only using the big antenna until a slightly smaller one arrived, it was a bit overkill, good reception though!
ajb
PostPosted: 13:25 - 28 Apr 2009    Post subject: Reply with quote
I'm pretty sure the radio function of most of the bike2bike comms are good, the lidl ones are good as walkie-talkies, it's just the headsets which are shite.
Rob
PostPosted: 13:59 - 28 Apr 2009    Post subject: Reply with quote
LOL! The only I reason that I laughed is that if you do get one (and for anyone that does have one) you will realise how well the thing attaches to your helmet - I think if it was being pulled, your neck would give way before the Scala mount does!
It's not stuck to the side, there is actually a very clever clamp that actually clamps to the side of the helmet.
Very well engineered! Thumbs Up
Pernig
PostPosted: 01:05 - 30 Apr 2009    Post subject: Reply with quote
+1 on this. The radios seem to work pretty well. I think the cables are thick enough to splice and solder in better mics and earpieces. If not they only use a standard 4-pin (I think) DIN socket. so shouldn't be too hard to knock up some wires.
H100 Breaking for spares
Rob
PostPosted: 12:47 - 30 Apr 2009    Post subject: Reply with quote
The problem is noise when you are traveling. You need noise canceling to make any bike comms usable. It doesn't matter how good your mic/earpiece is, without decent noise canceling you will get frustrated not being able to use them when moving!
Autocom have Noise cancelling licked! You can use most radios with em and it sorts out the rest.
Same as the scala rider's... they also noise cancel very well. - When I'm on the phone on the bike moving at speed people can't even tell I'm riding! That get's my Thumbs Up
c-m
PostPosted: 21:05 - 30 Apr 2009    Post subject: Reply with quote
Are there any intercoms rider to pillion that are:
a) Bluetooth
b) use fontopia type ear phones? I find that regular earpieces are awful in terms of music quality and some prevent you from wearing ear plugs so you'll eventually go deaf. The type of ear phone below kind of act like ear plugs in blocking outside sound and offer much better bass replication.
https://www.urban75.org/tech/images/sony-fontopia-mdr-ex71SLlg.jpg
ajb
PostPosted: 22:22 - 02 May 2009    Post subject: Reply with quote
I am sold on the Cardo Scala headsets.
https://www.motorcyclingmag.com/cardo_scala_rider_q2_motorcycle_headset_system_review
Above is a link to a review, which has an mp3 of a radio interview done with a dude whilst he was riding his ducati and using the cardo headset, sounds great.
c-m
PostPosted: 10:42 - 03 May 2009    Post subject: Reply with quote
a) Bluetooth
anyone?
Rob
PostPosted: 11:08 - 03 May 2009    Post subject: Reply with quote
c-m wrote:
anyone?
Well I can only suggest the Scala. The speakers fit behind the padding in your helmet so you can continue to wear your normal earplugs.. The Scala is loud enough to be heard without a problem. I wear foam earplugs and have no problems!
It sounds good and bassy with music also Thumbs Up
Skudd
PostPosted: 09:28 - 04 May 2009    Post subject: Reply with quote
Autocom works crystal clear upto 124mph. Whistle
With a lot of things that few extra pounds makes all the difference. My autocom is about 4 years old now and just had a few leads changed under general wear and tear but is still working as well as when it was first bought. The hours I've used it and the ease of use more than makes up for the price.
Pernig
PostPosted: 12:18 - 05 May 2009    Post subject: Reply with quote
a) Bluetooth
You could possibly use one of these, or something similar (read something that isn't cheap shit). This would do for your calls and music whilst allowing you to wear whatever headphones you choose. However, with one of these you would have no intercom unless there is a way to pair two bluetooth headsets (which I don't think there is without using a computer for them both to connect to) then you've hit a problem.
One idea is that there may be an application out there to call another phone via bluetooth. With a bluetooth headset paired to each phone and a call made from one phone to another (over bluetooth to avoid charges) it might be possible to set a sort of intercom up.
I found this which may work if you are using a phone with Symbian. If not, have a Google for a similar application for your phone's platform.
If you have unlimited data plans on both of the phones you could call one phone with another using a Skype client or similar (ie Fring). This, however, relies on having a signal, and it would probably be quite expensive if used abroad.
Phoenix
Twisted Firestarter
PostPosted: 21:45 - 05 May 2009    Post subject: Reply with quote
I think both of those ideas are unrealistic, bluetooth is extremly short range, maybe 15metres if you're lucky and i'm not aware of any phones that can provide a bluetooth-bluetooth call facility as due to the range you would be standing next to eachother anyway...
Skype and an internet connection would require a good signal which you will not have in many areas, and even if you do it will fluctuate and constantly disconnect.
A good bike comms unit is all there is if you want it to work properly, or walkie talkies for for something that'll work every now and then.
c-m
PostPosted: 22:15 - 05 May 2009    Post subject: Reply with quote
I think he was refering to me wanting a rider to pillion system that can use normal headphones and a seperate mic rather than some all in one jobby.
I have not seen any in-ear earphones in either the autocom or scala systems.
njd27
PostPosted: 10:15 - 06 May 2009    Post subject: Reply with quote
You can use in-ear earphones with autocom just fine - it just needs the cable 1188/1887 to connect it up.
Pernig
PostPosted: 10:18 - 06 May 2009    Post subject: Reply with quote
For a rider to pillion intercom the use of bluetooth would be more ideal than a regular radio signal, as using walkie talkies at such a short range can cause unwanted interference. The bonus of bluetooth for this application is that this is the range that it's designed for.
Perhaps there aren't phones that can call via bluetooth out of the box, but there could well be a third party application that makes this possible.
There are applications out there that can use Skype and/or their own protocols effectively in areas of low signal, but I agree it would probably be more hassle than it's worth.
The last post was made 17 years, 165 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 1.23 - MySQL Queries: 13 - Page Size: 139.13 Kb
