| Davie_G71 |
 Davie_G71 World Chat Champion
 Posted: 15:00 - 11 May 2009 Post subject: 1997 GSXR600 SRAD Problem |
Hello all,
As i pulled away from the petrol station after a run of about 20 miles at speeds between 50 and 100 i noticed a knocking that can be felt all through the bike, more like a clunk.
Symptoms:
1st gear, set revs to pull away, no knocking.
Let clutch out and start to pull away, a loud initial clunk and loads of smaller ones, not as loud.
2nd gear, let clutch out an accelerate, same thing, only not as loud.
This dissapears the higher i go in the range, or maybe it's happening but i can't feel / hear it as much.
I odn't think it's big ends as this would be evdent on just revving the engine, i'm thinking more gearbox / output shaft that sort of area.
The chain ans sprokets are worn and needing changing, i just hope i haven't broken anything big.
Any help greatly appreciated.
Davie ____________________ Suzuki GSXR600 SRAD, 1997 & Kawasaki Z1000, 2003. |
| Pete. |
 Pete. Super Spammer
 Posted: 15:06 - 11 May 2009 Post subject: |
Sounds like you've folded the teeth over on the front sprocket. If it was just in 2nd gear I'd say your gear dogs were knackered as they ahve a habit of going in 2nd. ____________________ a.k.a 'Geri'
| Davie_G71 |
| Pete. |
 Pete. Super Spammer
 Posted: 15:32 - 11 May 2009 Post subject: |
If it's ok you're gonna have to provide more acurate info. Firstly, check the chain. Does it have any tight-spots or is it adjusted too tight? This will produce a 'crunching' sound when you ride. ____________________ a.k.a 'Geri'
| lonner |
 lonner Spanner Monkey
| Davie_G71 |
| theshmoo |
 theshmoo Bottomless Pit
| Davie_G71 |
| BanditsHigh |
 BanditsHigh Worse than a woman
| Davie_G71 |
| BanditsHigh |
| Davie_G71 |
The last post was made 17 years, 154 days ago. Instead of replying here, would creating a new thread be more useful? |
