| bonceunounce |
 bonceunounce Banned
 Posted: 14:47 - 15 Sep 2003 Post subject: anyone for a shit heap? |
Just been playing with my NSR which top end blew up few weeks ago.
Decided to investigate why the wheel wont turn when its in gear, held the conrod and pulled upwards and the crank sort of spun halfway round, stopped and made a crunch and sort of a knock?
Im at my wits end with bikes, just said to scotty ill buy a 4 stroke next but when they fuck up its more expensive!!
Arghhh
Im going to go buy another moped, great fuel consumption, cheap to run and not as highly detonatable as a NSR  |
| Scotty |
 Scotty Scooter Boi
| Robby |
 Robby Dirty Old Man
| G |
 G The Voice of Reason
 Posted: 15:03 - 15 Sep 2003 Post subject: |
Oi!
Sort some of your other bikes robby .
Sorry, not sure about the problem though
Seriously if, you do want to get rid of it I'd be interested, or have a working engine that I could be tempted to sell (half the rest of the bike is knackerd, so looking for new bits or to break it).
If the engine is mashed there's usually one's going at fairly reasonable price from breakers. |
| Scotty |
 Scotty Scooter Boi
 Posted: 15:04 - 15 Sep 2003 Post subject: |
I'll steal the vents from it G  ____________________ Regards
Scott |
| bonceunounce |
 bonceunounce Banned
 Posted: 15:34 - 15 Sep 2003 Post subject: |
erm
Well, i cant work out whats going on, the crank only turns half a circle either way when its in gear, spins okay in neutral though.
Makes a crunchy sound, when i stick my fingers down that big dark hole i get remains of something stuck on my finger, probably bits of piston, barrel or ring.
Not sure what to do with it.
Its a sound bike it was Marks (MarsBars) on here.
Then it just packed up. Its had new back tyre, right front hanger and a few other bits done to it.
A engine would be another good option, but i dont even know if this one is fucked yet, ill have to get my mate round here or something.
250 lump smells nice, but then thats just asking for more problems, the NSR was never fast enough for me anyway
No point doing car lessons as i cant drive for shit, pedal bike?
Sorry chaps, too much going on in my head at the moment
/me needs a hug |
| Robby |
 Robby Dirty Old Man
| bonceunounce |
 bonceunounce Banned
 Posted: 16:15 - 15 Sep 2003 Post subject: |
Dirty Old Man
Very Appropriate  |
| Scotty |
 Scotty Scooter Boi
| bonceunounce |
 bonceunounce Banned
 Posted: 17:17 - 15 Sep 2003 Post subject: |
i put the old top end back on, minus the cyliner head and piston rings and pressed the starter, turns over fine so it must be the way i spinning it.
To be honest, id rather buy a old moped as a runaround and pass my test, then get a bigger bike, ive just lost all interest in it, its cost me a fortune since ive had it and i havent worked for 8 months and i cant afford to keep repairing it.  |
| Robby |
 Robby Dirty Old Man
| bonceunounce |
 bonceunounce Banned
 Posted: 17:38 - 15 Sep 2003 Post subject: |
erm its only the top end, its still worth something!
| Kickstart |
 Kickstart The Oracle
 Posted: 00:10 - 16 Sep 2003 Post subject: |
If it is in gear then the engine will not turn over. If you try you will just turn the crank which will turn the clutch, which will turn the gearbox and thus try and turn the back wheel.
A new barrel should sort it out, or repairing the one you have now. Think you said you needed a new head which Col can probably help you with. It will cost some money, but probably a lot less than selling it and buying another bike (which may well turn out to have problems of its own).
| bonceunounce |
 bonceunounce Banned
| Kickstart |
| bonceunounce |
 bonceunounce Banned
 Posted: 02:29 - 16 Sep 2003 Post subject: |
cheers keith
im gonna use it i think, im probably gonna keep the bike after the 2 hours i spent slaggin strokers and getting infuriated by it all!
Ive done my ped one a few times, just got to buy a torque wrench from somewhere now. I bet there a bugger to use!
Advice to anyone with a NSR when rebuilding top end - remove lower panels and the radiater, undo the top engine mounting bolt, and the front one behind the radiater,make sure front sprocket and chain is off and unclip the oil cable housing from the cable itself. The engine will drop forward and hang in the frame from the back by the remaining bolt, use a car jack to support it so it doesnt stretch a few of the remaining cables attached to it (oil ones etc)
Its a lot easier to work on this way.  |
| Scotty |
 Scotty Scooter Boi
| bonceunounce |
 bonceunounce Banned
 Posted: 14:54 - 16 Sep 2003 Post subject: |
Yeah, but if u let it sort of hang from the remaining bolt at the back and support it with a car jack , the front of the engine comes down by the front of the wheel area and the big space where the radiater was is now the space you have to remove the top end and that.
Im gonna have to go post the cheque for my parts!
Oh and my gudgeon pin, it has a small chip in it like the cylinder head had, about in the middle of the pin, shall i use it or replace it? |
| Scotty |
 Scotty Scooter Boi
| bonceunounce |
 bonceunounce Banned
 Posted: 16:32 - 16 Sep 2003 Post subject: |
I just did
I got a gasket set for £5.60 in the end off some bloke on find it, saved me £21.60.
So for £160.37 i got piston, barrel and rings, gudgeon pin and small end bearing, spark plug and a clutch cable
Im pleased, i had fun laughing at my mate, who payed £329 just to have his rings and piston changed on his RS aprilia!!
Now to go and put the wheel back on!
| Scotty |
 Scotty Scooter Boi
 Posted: 17:10 - 16 Sep 2003 Post subject: |
i'm pleased i got all of zak's / stoo's bike bits now.
YaY! least you know its going to a good home  ____________________ Regards
Scott |
| bonceunounce |
 bonceunounce Banned
 Posted: 18:12 - 16 Sep 2003 Post subject: |
i just need mccjams cylinder head
where is he  |
| bonceunounce |
 bonceunounce Banned
 Posted: 02:17 - 17 Sep 2003 Post subject: |
where colin?
i know he wants to sell me a radiater cheap befoe he sells it to scotty!!  |
| Scotty |
 Scotty Scooter Boi
 Posted: 10:21 - 17 Sep 2003 Post subject: |
naw my radiators fine (one of the few parts that is though ) ____________________ Regards
Scott |
| bonceunounce |
 bonceunounce Banned
 Posted: 14:22 - 17 Sep 2003 Post subject: |
The last post was made 22 years, 250 days ago. Instead of replying here, would creating a new thread be more useful? |
