I've done it again...
cal91
PostPosted: 00:44 - 01 Jun 2009    Post subject: I've done it again... Reply with quote
broke my car. Sad
https://i622.photobucket.com/albums/tt308/Cal91_2009/Photo017.jpg
https://i622.photobucket.com/albums/tt308/Cal91_2009/Photo020.jpg
https://i622.photobucket.com/albums/tt308/Cal91_2009/Photo019.jpg
That was a main earth wire for all the rear lights. The stupid spot weld has snapped off. I was trying to connect my subwoofer's earth wire to the bolt; but now i've fecked it.
The car starts and cuts out with the battery light flashing on the dash. Ive tested its this that is causing the cutting out.
Any suggestions??
We are the Patriots! Love your country.
Phoenix
Twisted Firestarter
PostPosted: 02:14 - 01 Jun 2009    Post subject: Reply with quote
Drill a proper hole, sand or grind the area to bare metal and find an appropriate nut and bolt to go in. then cut the 2 wires off that lump and crimp new eye terminals on and bolt them back.
Or if you aren't fussy you can just do the same as above without the new terminals, strip the insulation back a decent way on both, twist them together and wrap them around the bolt thread a couple of times and trap them in as you do the bolt up, just use a bolt with a large head or a washer so they don't come out.
cal91
PostPosted: 02:17 - 01 Jun 2009    Post subject: Reply with quote
Thats what I was thinking Wink
Would the metal rust if left as bare? Should I sand a very small amount off? Such as with a small hand drill and the right sanding drill bit?
Fawbish
PostPosted: 14:34 - 01 Jun 2009    Post subject: Reply with quote
Cover it in copper grease/vaseline, it will be fine.
Dragonfly
PostPosted: 14:49 - 01 Jun 2009    Post subject: Reply with quote
It is a Fiat?
(fix it again tomorrow)
All the breast.
Muzza on Binge:
cal91
PostPosted: 01:00 - 02 Jun 2009    Post subject: Reply with quote
No its a SEAT Ibiza.
I managed to drill a new hole etc.
But the subwoofer still isn't working. The cars fine now though and thats the main thing.
Its just the sub keeps blowing fuses.
cyberglass
PostPosted: 01:11 - 02 Jun 2009    Post subject: Reply with quote
if its blowing fuses its either a fucked sub or you have wired it wrong go over all your wiring and check for any damage.
Try running the sub straight to the battery (have an inline fuse) and see if it works that way.
DL650 Vstrom 2004
DRZ400S 2003
Yamaha R1 2005
cal91
PostPosted: 01:18 - 02 Jun 2009    Post subject: Reply with quote
It blew it's fuse on the amp when I tried to connect it to the battery (lots of sparks).
Then everytime I replace the fuse it sparks and blows it. So I disconnected it from the battery (buy pulling out the fuse in the power cable) and replaced the fuse in the amp. But now it blows on the cable.
I've checked the wiring and it seems fine
Ive checked the remote wire (works when cars ignition is on and stops when its off) can't check the power cable, but it blew the fuse in the amp amp, so that must be working.
I was earth'ing the voltmeter with the amps earth cable and it was working fine so I am clueless :S
The wiring to the subwoofer seems all connected but I don't think that should matter. The amp should still work.
So what do you think? broken amp?
cal91
PostPosted: 01:28 - 02 Jun 2009    Post subject: Reply with quote
Do you think its a bad earth?
How would I check this?
The last post was made 17 years, 125 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.75 - MySQL Queries: 14 - Page Size: 61 Kb
