 deano_Racer L Plate Warrior
 tshort2007 Scooby Slapper
 Posted: 20:57 - 15 Jun 2009 Post subject: |
If your main fuse has blown, its usually an indication that a live (+) wire has come into direct contact with the frame, or something connected to the frame.
If your indicators dont work, its possibly your relay, usually located under the seat.
As for wiring the headlights, you have only 2 wires. If you mix them up, it wont matter, as standard bulbs are bi-directional on current (it doesnt matter where the + or - connects to, it still works)
If you have LED bulbs, the wires only work one way, but it wont cause any damage if you wire them wrong. they just wont work! Easy! |
