| Dr. DaveJPS |
 Dr. DaveJPS World Chat Champion
| Mudskipper |
 Mudskipper World Chat Champion
 Posted: 08:32 - 30 Apr 2009 Post subject: |
Me likey.  ____________________ CBR125|||GSXR400|||CBR400|||CBR400|||CB250RS|||GSXR750|||CB250RS
"You're clumsy, you eat too much and you behave like a 12 year old boy. But you know what? Every once in a while, you find a thumb." |
| Dr. DaveJPS |
 Posted: 13:51 - 30 Apr 2009 Post subject: |
thanks,
it has all the mod cons,
cruise control, (well a non return throttle)
gear indicator, (litrally a piece of metal on the lever to show where it's stopped)
loud pipes, (cause there wan't any of theis noise control malarky when it was built)
Edit: forgot the "scotoiler" (oil breather pipe is directly over the chain)
and she'll still hit an indicated 85 (chin on tank feet on pillon pegs)
 ____________________ "intelligent inattention is preferable to unintelligent tinkering"
www.davejps.com |
| garth |
 garth World Chat Champion
 Posted: 14:49 - 30 Apr 2009 Post subject: |
Lol, gear indicator.
My old man has an ES2 with the gears stamped on the gearbox. In the wrong order
1N243, apparantly.
 ____________________ You ain't a has been if you never was |
| wizzzard |
 wizzzard World Chat Champion
 Posted: 12:58 - 02 May 2009 Post subject: |
An absolutely stunning bike that is even better in the flesh ( or metal as it were )
I want one so bad now  ____________________ And did you exchange a walk on part in the war for a lead role in a cage?
Zeitgeist / Addendum / Moving forward |
| Dr. DaveJPS |
| Dr. DaveJPS |
 Posted: 21:53 - 12 May 2009 Post subject: |
was riding tonight, went to change up a gear and when i did i lost power to the rear wheel, pulled to the side of the road and killed the engine.
looked it over and couldn't see anything wrong (had been worried the sump had come out or something).
tried to restart but gear indicator was stuck at 2/3, with no resistance to rolling backwards.
eventually got it indicating neutral but it wouldn't start and i had to get recovery
any suggestions? or can someone suggest somebody local to leeds who whould be able to diagnose/fix? ____________________ "intelligent inattention is preferable to unintelligent tinkering"
www.davejps.com |
| Dr. DaveJPS |
 Posted: 21:43 - 20 May 2009 Post subject: |
well, having had the local NOC'ers look it over it appears it is not a gearbox problem, but was most likely due to clutch overheating.
also found out what i thought was choke off (and was having to add choke to get it to run) was actually choke on though i'm blaming my stepdad for that 'un
now have more jobs for the bank holiday weekend including;
moving the gearbox backwards,
refilling the gearbox oil and primary chain oil
buy a new clutch cable and fuel line
remove and clean gunk oil tank
and give it a shake-down run and find the next load of issues
will post pictures as i do the work.  ____________________ "intelligent inattention is preferable to unintelligent tinkering"
www.davejps.com |
| Dr. DaveJPS |
 Posted: 22:28 - 20 Jun 2009 Post subject: |
| Dr. DaveJPS |
 Posted: 22:47 - 20 Jun 2009 Post subject: |
| mrtEE |
This post is not being displayed because it has a low rating (Abusive). Unhide this post / all posts.
 mrtEE World Chat Champion
 Posted: 23:48 - 20 Jun 2009 Post subject: |
| Dr. DaveJPS |
 Posted: 10:39 - 21 Jun 2009 Post subject: |
yeah i ken i'm ugly that is why i don't normally post pictures of myself, you cunt  ____________________ "intelligent inattention is preferable to unintelligent tinkering"
www.davejps.com |
| Ant132 |
 Ant132 World Chat Champion
 Posted: 13:04 - 21 Jun 2009 Post subject: |
Your Dominator looks amazing!  ____________________ 1980 Suzuki TS50 ~ 1984 Honda CB400N ~ 1992 Triumph Trident ~ 1998 Suzuki Bandit 1200 |
| Dr. DaveJPS |
 Posted: 14:19 - 21 Jun 2009 Post subject: |
cheers ANT132,
i actually met the guy who built it in 1968, and found out it isn't a 500, the frame is from a 88 (500), the engine casing is a 99 (600cc) with an SS crank and a 650ss top end (so is still a 600 cause of the crank) ____________________ "intelligent inattention is preferable to unintelligent tinkering"
www.davejps.com |
| Suitor_Stu |
 Suitor_Stu Could Be A Chat Bot
| Kickstart |
 Kickstart The Oracle
| Dr. DaveJPS |
 Posted: 17:08 - 23 Jun 2009 Post subject: |
aye those are speedmaster MKII, i replaced the originals (well 69 ish) this summer and found it a lot better as it had a 4.00 tyre instead of a 3.50 which was what i put on there.
as for handling for all the epic lean angle you see in the pics i have about 1mm of chicken strip left
the flight suit was my stepdads, and i wear it over my leathers so i can get away with a one piece on a old bike, (plus this time it meant i didn't have to worry about my wallet etc while i was on track as they were on me ) if you want one i've found this place (https://www.the-outdoor.co.uk/ishop/853/shopscr258.html) but expect gentle ribbing from people as to where you've parked the tornado.
aye keith it was good to see so many rotaries including 3-5 (of the 30 built) of the F1 sports, there where quite a few race rotaries too ____________________ "intelligent inattention is preferable to unintelligent tinkering"
www.davejps.com |
| Mudskipper |
 Posted: 10:23 - 24 Jun 2009 Post subject: |
Nice pics!
I love the bit of cardboard underneath for catching drips
https://i609.photobucket.com/albums/tt180/DaveJPS/P6190021.jpg?t=1245534260 ____________________ CBR125|||GSXR400|||CBR400|||CBR400|||CB250RS|||GSXR750|||CB250RS
The last post was made 17 years, 97 days ago. Instead of replying here, would creating a new thread be more useful? |
