gear lever is loose!
kingrico
PostPosted: 09:18 - 22 Jun 2009    Post subject: gear lever is loose! Reply with quote
I have noticed that the gear lever on my ER-5 was become quite loose i.e. it wobbles side to side. It doesn't really seem to affect the changing of gears to much but how would you go about tightening the gear lever?
Davie_G71
PostPosted: 09:22 - 22 Jun 2009    Post subject: Reply with quote
Depends what you mean by loose. Is there play in the rod end ball joints? If so you need to replace the ball joints. The aren't expensive but you may have to cut the old ones off.
I have the same issue on my SRAD.
David.
Suzuki GSXR600 SRAD, 1997 & Kawasaki Z1000, 2003.
rob_scott92
PostPosted: 11:11 - 22 Jun 2009    Post subject: Reply with quote
if its just the lever thats wobbling, then try taking it off and put a couple of washers in there to close the gap. this worked for me Smile .
hope this helps Thumbs Up
Rob Thumbs Up Cool
mudplug
PostPosted: 13:03 - 26 Jun 2009    Post subject: Re: gear lever is loose! Reply with quote
Hmmm I think we need a bit more detail about this "side-to-side" movement.
By "side-to-side", do you mean "in & out" = towards the engine / away from the engine?
This problem on ER5s is usually caused by a worn Selector Shaft = the splined shaft that the lever clamps onto.
(The ER5 has a simple one-piece gear lever clamped to a splined shaft, so no problems with rod end ball joints.)
It's not a very difficult job to change the selector shaft. I can have a look on a spare engine and write a little guide if you like. PM me if you'd like me to do this Wink
Also I've got a spare selector shaft if that turns out to be your problem.
Stefan.
(mudplug)
The last post was made 17 years, 121 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.43 - MySQL Queries: 14 - Page Size: 39.97 Kb
