Lubing Clutch Cable.
johnsmith222
PostPosted: 10:55 - 24 Jun 2009    Post subject: Lubing Clutch Cable. Reply with quote
Hi.
I'm going to do the baggie/elastic band technique to lube my clutch cable.
My question is that is it ok to use 10w40 engine oil or will the cable be dry within a week?
Polo
PostPosted: 10:58 - 24 Jun 2009    Post subject: Reply with quote
Should be fine, anything is better than leaving it dry. I use 3in1 and it keeps it nice and greasy. Thumbs Up
My mum smells your fingers
johnsmith222
PostPosted: 11:01 - 24 Jun 2009    Post subject: Reply with quote
well done with the 3 in 1 tip.
I forgot I even had that! Cool
PostPosted: 11:25 - 24 Jun 2009    Post subject: Reply with quote
Depends on the cable. Many cables have nylon liners which expand with oil, so making the cable stiffer.
dr_adams
PostPosted: 11:29 - 24 Jun 2009    Post subject: Reply with quote
i would go with some thicker oil, normal oil will not last, would personally try some lithium grease...
yuri2085
PostPosted: 14:20 - 24 Jun 2009    Post subject: Reply with quote
baggie elastic band what now?
Also how does one lube the throttle cable? Do you need to undo the housing on the bars?
johnsmith222
PostPosted: 15:15 - 24 Jun 2009    Post subject: Reply with quote
https://i19.photobucket.com/albums/b167/bvail/Clutch2DCable2DLube2DBaggie.gif
takes about 10 minutes for the oil to go right through but it works great
As for the throttle cable, you do need to remove the housing to lubricate it (or at least you do need to on my CG). I'm sure you could do the baggie technique for the throttle cable too.
Finglonga
PostPosted: 15:57 - 24 Jun 2009    Post subject: Reply with quote
This.
It could make things worse and not better.
Andy Sez....
F.Y.Y.F.F.
Polo
PostPosted: 15:51 - 25 Jun 2009    Post subject: Reply with quote
Finglonga wrote:
This.
I have never had an issue with it and the internet seems to be awash with people saying to oil them regularly? Thinking
Finglonga
PostPosted: 17:25 - 25 Jun 2009    Post subject: Reply with quote
Nor me, was told not to years ago by a techie that had come across the prblem . . . . But then again I have never needed to oil one.
Andy Sez....
F.Y.Y.F.F.
The last post was made 16 years, 230 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.35 - MySQL Queries: 14 - Page Size: 64.67 Kb
