NSR125
Lee
PostPosted: 15:20 - 24 Jul 2003    Post subject: NSR125 Reply with quote
I have moved the NSR125 FAQ to HERE, where it is regularly updated, and is also now linked to the UK & import de-restriction guide, as well as other guides such as changing carburetor jets etc. More guides are being added all the time.
The NSR125 User manual can still be downloaded HERE
Lee
Kris
PostPosted: 15:22 - 24 Jul 2003    Post subject: Reply with quote
You should say that you have to remove the seat before you can lift the tank up - but apart from that you've got it all covered Very Happy
www.prisonplanet.com
irdawood This post is not being displayed because the poster is banned. Unhide this post / all posts.
Lee
PostPosted: 19:58 - 24 Jul 2003    Post subject: Reply with quote
Cheers guys Very Happy
Have edited in the bit about the seat / tank Smile
debzw1
PostPosted: 16:56 - 01 Aug 2003    Post subject: ruddy brilliant! Reply with quote
Very Happy HI came for a peek and i cant believe it!!!
I have a NSR 125 without any manuals so most of the work i need to do on her is guess work! yep i stuggled with the damn seat!and the oil and the water! Embarassed
So BIG thanks going out to LEE Very Happy
One more thing before i go.... how can i stop the grey smoke comin out my exaust?
Demonic69
The Pink Rhino
PostPosted: 17:06 - 01 Aug 2003    Post subject: Re: ruddy brilliant! Reply with quote
You can't. It's a 2 stroke and the smoke's from the oil. It'll stop once it's warmed up enough Razz
TGE125NSR This post is not being displayed because the poster is banned. Unhide this post / all posts.
Lee
PostPosted: 18:06 - 01 Aug 2003    Post subject: Re: ruddy brilliant! Reply with quote
Glad it helped you mate Smile As for the smoke, have you tried using Putoline TT Sport 2 stroke oil? It claims to give off less smoke and scent than the other 2 stroke oils. It is normal for it to smoke though, all 2 strokes do it.
Also as you are missing the owners' manual, i have just updated the guide above with some more things including a link to download the owners manual.
Lee
Scotty
Scooter Boi
PostPosted: 18:14 - 01 Aug 2003    Post subject: Reply with quote
If the engine is cold / Early in the morn, it will smoke allot more, due to it having to use the choke, and burning up unburnt oil thats floating round.
Make sure not to over rev while its cold. The most engine wear is undertaken while the engine is cold.
If the bike still smokes after the bike has warmed up / ridden for about 5-10 mins, you can adjust the oil pump cable. (much easier to do on the unfaired models Very Happy)
I found i had mine set for max, and it would use about 500mil of oil in about 300km, which is far to much,
And the huge clouds of smoke kind of gave it away i had the setting wrong...
You shouldn't really have any smoke coming out the exhaust once the bike is warm.
Although its not really a problem, its better to have to much oil going through, than not enough and causing a seize.
Rolling Eyes
Regards
Scott
debzw1
PostPosted: 12:42 - 02 Aug 2003    Post subject: Reply with quote
Thanks for all replys Very Happy
smoke from exaust is ok when engine is warm, will try adjusting the oil pump cable, if i can find it that is Confused
will download manual Very Happy brilliant!!!!
hey you wanna see my rear mud flap...looks more like digging implement Razz
Lee
PostPosted: 15:09 - 02 Aug 2003    Post subject: Reply with quote
LOL! its easy to remove, and looks better without it. i think its just 2 bolts, 1 either side at the top of the mudflap. This was the first thing i did when i got my NSR home!
bobcat
PostPosted: 11:47 - 03 Aug 2003    Post subject: Reply with quote
bloody hell ! is this site for real or what? I have an nsr but my owners manual is in french/german. Ive been all over the place trying to get info on what oils to use ect with no joy. So many thanks to LEE. Cheers mate you just made my day.
PostPosted: 12:01 - 03 Aug 2003    Post subject: Re: NSR125 Reply with quote
Brakes:
Most importantly, motorcycles are not like mountain bikes – you do not use mostly the back brake. You should aim for (roughly) 70% front and 30% rear. Oh and do not brake hard while cornering, or you will be sitting on your arse sliding towards the outside of the corner! To change the front and rear pads, follow the guides at nsr125.com (click here)
Generally most people end up using 100% front and only the rear very occasioanly.
Braking with teh frotn while cornering should in most circumstance be avoided.
It will make the bike sit up and possibly the front wheel lose traction if well leant over.
If it's a case that there's a hazard of some sort that can't be avoided and you're not well leant over, it shouldn't be a prob.
However as a soloution to going into a corner too fast it's one of the worst things you can do. It will most probably either make you run wide or make the front slide. 9 times out of 10 the bike can make the corner, even if you think it can't.
Slight pressure on the rear brake will slow you down in the corner, but you need to be very sure you're not going to lock it.
Due to the relative contact sizes of the the frotn and rear tyres you should ideally be accelerating slightly around corners, to weight the rear tyre with 60% of the bieks weight, so the smaller front only has 40%.
ilovens125f's
PostPosted: 00:25 - 23 Nov 2003    Post subject: Re: NSR125 Reply with quote
Lee
The link dont work Sad
Kev the Ns125F lover!!
!!!Dont ignore me!!!
Scooby
Scrappy Doo
PostPosted: 00:27 - 23 Nov 2003    Post subject: Reply with quote
It probably did when it was posted back in July.
NSR125-Kid-UK
Attention Whore
PostPosted: 05:50 - 27 Nov 2003    Post subject: Reply with quote
Either way it's good that all the NSR'ers are getting the support which they obviously appreciate Smile.
https://www.bikepics.com/members/nsrandy/96rs250/ My Bike!
"I'm either going to teach andy to get his knee down, or I'm going to get him killed. One of the two" - Teaman
There is a gap of 4 years, 62 days between these two posts...
arin
PostPosted: 03:24 - 28 Jan 2008    Post subject: Reply with quote
anyone got this faq to hand??
The last post was made 18 years, 246 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.38 - MySQL Queries: 13 - Page Size: 94.88 Kb
