| Polo |
 Polo World Chat Champion
 Posted: 07:30 - 04 Sep 2009 Post subject: Do I have a rectifier/regulator problem? |
Hi peeps.
Before I splash out on a replacement, I just want to confirm that it is the rectifier that is dying.
My battery is but 6 months old at most. It pulls in 14.1 volts when my lights are off but only a maximum of 11 when the lights are on.
Meaning a night ride ends up with me having to bump start the bike when I cut the engine. Not a problem really - it's what pillions were invented for.
Is the boney finger of suspicion well and truly on the rectifier?
Many thanks.  ____________________ My mum smells your fingers |
| stinkwheel |
| Polo |
| stinkwheel |
 Posted: 09:21 - 04 Sep 2009 Post subject: |
Do you have access to an ammeter (a high load one, 30A+ NOT a multimeter). This can give you a much better idea of how much power is going into/out of the battery when connected in series with the main fuse.
To be honest, it sounds more like a battery problem. I'd check the battery terminals are tight and corrosion free and check for a bad connection at the reg/rec terminal block and the main fuse holder.
Also check the battery electrolyte level if it isn't a sealed one.
Any other accessories (heated grips/alarm etc.).
EDIT: Standard lights? ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Polo |
| Kickstart |
 Kickstart The Oracle
| Polo |
| Kickstart |
| SW Motech Shop UK |
 SW Motech Shop UK Scooby Slapper
The last post was made 17 years, 25 days ago. Instead of replying here, would creating a new thread be more useful? |
