| Handsome |
 Handsome World Chat Champion
 Posted: 10:56 - 15 Aug 2009 Post subject: ARRRRRRRRRRRRGGGGGGGGGGGGHHH.....FFS... |
Short version :...
Suzuki SV 1000 S '54 plate...
Changing the oil last week I had to put a fair bit of weight behind undoing the sump plug bolt as I'm guessing either He-Man owned the bike before me or it was put back in with an air tool, resulting in me taking the thread out of the sump...
I've taken the bolt to places that sell Heli-Coil Kits to try and get it sorted that way, they are suggesting retapping it out to 14mm, but I'm not so sure on how that would hold as I really don't like the thought of it pissing oil out and onto my back wheel while I'm riding thankyouverymuch...
I've sent a request off on Partfinder so I'm awaiting to be told no one has one as the thirty or so breakers I've looked at don't seem to have anything for a 1000, 650 yes but not a 1000, which could be looked as a good way I suppose !...
So whilst I'm staring at a bike that I had to throw nearly three hundred quid at the other week ( Don't ask ) has anyone got any suggestions or can you think of anything I'm overlooking...
Right now I've got the arsehole with biking and THIS FUCKING BIKE, I bought a newer bike as I was looking for reliability and easy maintence ffs, my old Kwak never let me down, so much for new/newer !!!
 ____________________ Previous Bikes...Honda NSR 125 RR...Kawasaki Zephyr 550...Suzuki SV 1000 S...Yamaha FZ8...Current Bike...Suzuki GSX-R 750... |
| tutton |
 tutton World Chat Champion
| nowhere.elysium |
 nowhere.elysium The Pork Lord
 Posted: 11:05 - 15 Aug 2009 Post subject: |
| Handsome |
| Pete. |
 Pete. Super Spammer
 Posted: 12:02 - 15 Aug 2009 Post subject: |
It's very common to strip the threads when un-doing a sump bolts. Suzukis seem to do it for a pastime.
If it had a 12mm sump bolt in it that's stripped you might be lucky enough to just run a 14mm tap through the hole coz the drill size for M14 is 12mm.
It won't make the hole brittle and should work just fine. You could even do it in place. ____________________ a.k.a 'Geri'
| Handsome |
| Handsome |
 Posted: 16:51 - 15 Aug 2009 Post subject: |
Cheers CHRI5, I'll get hold of a 14mm tap then as he couldn't find his and a new bolt and take it down in teh van...
Cheers guys... ...Karma given... ____________________ Previous Bikes...Honda NSR 125 RR...Kawasaki Zephyr 550...Suzuki SV 1000 S...Yamaha FZ8...Current Bike...Suzuki GSX-R 750... |
| Handsome |
 Posted: 09:47 - 02 Sep 2009 Post subject: |
Right...
I didn't take the bike to the garage for him to do it, seeing as I could do it myself...
I've run a 14mm tap through it and got the right sized bolt, but...
As the bolt goes in there's a lot of play, sideways, untill it reaches the top of the hole then there's no play, but, it will not lock off, it just keeps turning, so...
I've thought about taking the sump off and taking it down a mates-mates place for him to drill it out and retap it for me and make sure a bolt fits, but, I've just phoned a bike shop to find out a price for a new gasket for the sump and he recons it's an engine strip job as he says the sump itself is part of the engine and not an actual removable part ?...Anyone know if that's right as I don't have a manual and I haven't had chance to look at the bike as of yet as you can't see much with the firings on, and to get to the sump ( if it's removable ) I need to take the fairings off and most of the exhaust...
Any ideas ?...
Or Or Or, is it worth locktighting the fucking bolt in and when it comes to oil changes use a syphon pipe ( the one with the squeezey hand pump in the middle ) to take it out from the top ?...
Getting the right arsehole with this now tbh... ____________________ Previous Bikes...Honda NSR 125 RR...Kawasaki Zephyr 550...Suzuki SV 1000 S...Yamaha FZ8...Current Bike...Suzuki GSX-R 750... |
| sickpup |
 sickpup Old Timer
| Handsome |
| MaybeGuy |
 MaybeGuy Super Spammer
 Posted: 15:31 - 02 Sep 2009 Post subject: |
jb weld ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
| LeeR |
 LeeR World Chat Champion
 Posted: 17:55 - 02 Sep 2009 Post subject: |
I apologise if I'm off target with this comment, but don't forget to part search on DL1000, TL1000 R/S, and Cagiva Navigator as they use the same engine, maybe not necessarily the same sump, but worth a try. ____________________ My claim to fame: Austin Vince nicked my pen... |
| Wafer_Thin_Ham |
 Wafer_Thin_Ham Super Spammer
| sickpup |
 sickpup Old Timer
| MaybeGuy |
| sickpup |
 sickpup Old Timer
| binge |
 binge Emo Kiddy
| Handsome |
 Posted: 20:25 - 02 Sep 2009 Post subject: |
| CHR15 wrote: | so,assuming you have tapped to 14mm id find a drill / tap size guide find the next size up, ie. drll it with a 15 mm drill, making sure your going in straight and not ovaling the hole.
then get the right size tap, tap it, get a normal bolt cut down to the correct length, copper washer and a tiny, teeny weeny bit of locktight. dont cover it because youl kick yourself when for some reason you do need to take it out. |
I've tapped it out to 14mm with a 2.0 pitch, got the right sized bolt and cut it down...As you look into the hole it looks as though it's just thread all the way up ( hardly any gap between said thread and hardly any depth in the thread)...
The next thing to try was as you've suggested, if I can get it off the ground to get clearance to drill it out how much of a problem would it be to get rid of any swarf that goes in the block ?...When I tapped it I just ran some oil through it, all that came out was a few bits tbh though...But...
Call me stupid, if the bolt has freeplay as it's going into the hole due to lack of credible thread could I run a 15mm tap through it without drilling it out seeing as I can wiggle the bolt ( reason I ask is seeing as a tap has a tapered end, would that start enough thread to pull the rest of the tap through, or am I just imagining this would work )... ____________________ Previous Bikes...Honda NSR 125 RR...Kawasaki Zephyr 550...Suzuki SV 1000 S...Yamaha FZ8...Current Bike...Suzuki GSX-R 750... |
| MaybeGuy |
| sickpup |
 sickpup Old Timer
| MaybeGuy |
| sickpup |
 sickpup Old Timer
| Handsome |
| MaybeGuy |
 Posted: 21:33 - 02 Sep 2009 Post subject: |
so a money saving suggestion changes my job does it?
anyway, a quick check on ebay says you can pick one up for £550. then you can break the other for spares.
its only a sump plug though. a new engine is fucking excessive. ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
| sickpup |
 sickpup Old Timer
The last post was made 17 years, 75 days ago. Instead of replying here, would creating a new thread be more useful? |
