| nowhere.elysium |
 nowhere.elysium The Pork Lord
 Posted: 08:37 - 15 Sep 2009 Post subject: 1996 GSF600 carb question |
Hi all. The airbox on my Bandit melted due to an excess of petrol being spat into it over a long period of time (read: before I bought it). I had to temporarily replace it with a set of pod filters. Now - I've been checking the plugs religiously, because I don't like the idea of killing an engine with a lean mixture.
However, it's been largely fine: the plugs are coming up an OK colour, and although the flatspots have returned in some force, they're only between about 4.7K to about 6.5K - I'm led to believe that this is around the rev range where the needles are used to determine fuel flow. My problem is that I can't adjust the needle position, because they have no notches: they just sit at the height that's set as standard.
Is i possible to buy some adjustable needles for these carbs? They're CVK32s. Failing that, can anyone suggest a good material to fashion some shims from? I had thought of using some steel, but since the needles are made from brass, I didn't want to knacker them too quickly if I could avoid it...
I consider buying a dynojet kit as a bit of a last resort, because money's bit on the tight side at the moment. If it's the only way, then it's the only way, but I'd rather be spending money on decent brake lines first, if I can. ____________________ '10 SV650SF, '83 GS650GT (it lives!), Questionable DIY dash project, 3D Printer project, Lasercutter project |
| sickpup |
 sickpup Old Timer
| nowhere.elysium |
 Posted: 09:07 - 15 Sep 2009 Post subject: |
That's the conclusion I was coming to.
My only problem with this is that it was a complete sod to remove the previous airbox: I can't get the bloody carbs off the inlet rubbers - they've seized. If there's an easy, non-destructive way of solving this, then I've got no problems at all... ____________________ '10 SV650SF, '83 GS650GT (it lives!), Questionable DIY dash project, 3D Printer project, Lasercutter project |
| Kickstart |
 Kickstart The Oracle
| nowhere.elysium |
| Kickstart |
| nowhere.elysium |
 Posted: 10:15 - 15 Sep 2009 Post subject: |
| temeluchus |
The last post was made 17 years, 10 days ago. Instead of replying here, would creating a new thread be more useful? |
