top box mounting/tie down points - Solution Found :)
squishio
PostPosted: 20:27 - 11 Sep 2009    Post subject: top box mounting/tie down points - Solution Found :) Reply with quote
Hi All
I need to strap a tent to the top of my top box for my trip next week, however I would really like to be able to open the bow while the tent stays on top.
I will secure it with bungees but I need some sort of tie down points. I have been searching for quite a while but cant find anything small enough to look proportionate.
All I keep finding are tie down points for vans etc which are huge.
What I would ideally like is something like this....
https://www.rdphoto.co.uk/mg2/pictures/top%20box.jpg
something that could screw in from the inside.
is there a particular name that these would come under?
Cheers!
Rich
Current - Hornet 600, Transalp 650, X140 Pit, GPZ400R
Past - SY125, GT250, GT650, CX400, CBF600, Bandit 600, SL1000, GT250
Skudd
PostPosted: 21:34 - 11 Sep 2009    Post subject: Reply with quote
Somethin like these?
https://images.google.co.uk/imgres?imgurl=https://deycore.com/images/eyelets_large.jpg&imgrefurl=https://deycore.com/fox_act_parts.htm&usg=__oft2vUL5Icl1oRyTlR5JUH9enBs=&h=389&w=432&sz=29&hl=en&start=67&tbnid=eTlFoPo6JNHjcM:&tbnh=113&tbnw=126&prev=/images%3Fq%3Deyelets%26gbv%3D2%26ndsp%3D21%26hl%3Den%26sa%3DN%26start%3D63
KevTM
PostPosted: 21:37 - 11 Sep 2009    Post subject: Reply with quote
2 bolts and 4 nuts.
Drill hole.
Put one nut on bolt about 10mm from the head.
Slot bolt in hole
put the other nut on from inside
tighten up
do other side.
washers recommended.
should give you enough to bungy to.
squishio
PostPosted: 21:40 - 11 Sep 2009    Post subject: Reply with quote
something like that yeah, but I would prefer it to flap down....
pretty much this but smaller...
https://www.autow.co.uk/images/products_large/TF855.jpg
but they are 10cm across so they're HUGE!!
Skudd
PostPosted: 21:44 - 11 Sep 2009    Post subject: Reply with quote
r use a small exhaust clamp ( car) have the U shap on the outside. https://images.google.co.uk/imgres?imgurl=https://www.americanpartsdepot.com/images/941%25207804As.JPG&imgrefurl=https://www.americanpartsdepot.com/FuelExhaust2.htm&usg=__ssYKnJWxL9sJzsFhA85HgZLNrks=&h=1158&w=1833&sz=353&hl=en&start=10&tbnid=RHPOKuoFwY6g0M:&tbnh=95&tbnw=150&prev=/images%3Fq%3Dexhaust%2Bclamp%26gbv%3D2%26hl%3Den%26sa%3DG
squishio
KeV6 wrote:
2 bolts and 4 nuts.
Drill hole.
Slot bolt in hole
tighten up
do other side.
Makes sense Smile would prefer a hoop as it would be usefull for other bits as well.
but may well end up doing this Cheers!
I really need a d-ring the size on a helmet strap but mounted on some sort of fixing....
Bendy
Mrs Sensible
PostPosted: 21:45 - 11 Sep 2009    Post subject: Reply with quote
Maybe think haberdashery rather than hardware... the kinda things you'd use to attach a strap to a bag should be more like the right size and could be screwed / rivetted to the topbox.
KevTM
PostPosted: 21:47 - 11 Sep 2009    Post subject: Reply with quote
I just like the 'budget' (cheapskate) way Laughing
Never have seen the likes of what you're looking for though Thinking
stutterin' sam
PostPosted: 22:11 - 11 Sep 2009    Post subject: Reply with quote
bought small ones similar to what you want in B&Q for the same purpose
Fixed them to my top box with blind (pop) rivets
It is said that if you line up all the cars in the world end to end, some idiot on a sports bike would be stupid enough to try and pass them.
Im-a-Ridah
PostPosted: 23:12 - 11 Sep 2009    Post subject: Reply with quote
Well here is but a few ideas...
Get some strap webbing, fold it creating a U-shape, then stick a bolt through it with a washer on either side and then attach to the point on the bike of your choosing. Alternatively, buy some wire rope joiners and attach them to a point on the bike, or if you want them out of sight use them to grip some wire rope to the bike and create a hoop of wire rope. Wire rope is available by the meter in B&Q IIRC. Webbing strap can be bought there too, but wilkinsons or the like will likely have a set of straps for £1 or so, which probably works out a lot cheaper. The wire rope fixings aren't very long, so perhaps bolt on some chain with a washer, simpler too albeit not as subtle as wire rope.
Wire rope fixing
https://www.screwfix.com/prods/22989/Ironmongery/Chains-Accessories/Wire-Rope-Accessories/Standard-Wire-Rope-Fixings-M6-Pack-of-10
https://www.screwfix.com/sfd/i/cat/79/p1663379_l.jpg
Webbing strap
https://media.rei.com/media/709053_193Lrg.jpg
squishio
PostPosted: 10:53 - 14 Sep 2009    Post subject: Reply with quote
As per Ridah's suggestion I have done pretty much what he suggested...
strap folded washers and rivet....
https://www.rdphoto.co.uk/pictures/IMG_1663_medium.JPG
https://www.rdphoto.co.uk/pictures/IMG_1664_medium.JPG
https://www.rdphoto.co.uk/pictures/IMG_1662_medium.JPG
Rivet on the inside...
https://www.rdphoto.co.uk/pictures/IMG_1666_medium.JPG
https://www.rdphoto.co.uk/pictures/IMG_1668_medium.JPG
KevTM
PostPosted: 10:54 - 14 Sep 2009    Post subject: Reply with quote
Looks good Thumbs Up Neatly done!
squishio
PostPosted: 11:26 - 14 Sep 2009    Post subject: Reply with quote
Cheers! Seems pretty strong Smile I haven't had the tent on there yet but pretty certain it will hold.
iooi
PostPosted: 12:25 - 14 Sep 2009    Post subject: Reply with quote
Nice idea.
And no end cheaper than the racks that you can buy to go on top of the boxes...
Just hope the quick release system on the box is upto the extra drag, and does not decide to give while you are on the road.
The last post was made 16 years, 128 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.62 - MySQL Queries: 14 - Page Size: 84.01 Kb
