Is it easy to change a car door?
dransy
PostPosted: 13:21 - 18 Sep 2009    Post subject: Is it easy to change a car door? Reply with quote
HI all just a few questions...
The missus crashed into a bus and knackered her door.
I bought one from some scrappers , i just put on the primer and will be spraying it sometime.
Now how easy/hard is it to fit a door?
My main worry is that i have to take everything out of the old door to fit into the new one as the new one is just a shell. So i gotta take out all the glass , the handles , electrics *etc*
Any tips advice or should i just go along with flow ?
Oh and its a rover metro if that helps Smile
Skudd
PostPosted: 13:30 - 18 Sep 2009    Post subject: Reply with quote
Stripping doors is dead easy, take photos while you are doing it so you can remember what goes where. take your time, stip the old door before you take it off and again replace everything after you have put the new door on.
PostPosted: 13:43 - 18 Sep 2009    Post subject: Reply with quote
I may be stating the obvious, but put the stuff on the new door in the reverse order you stripped it from the old one - i.e. the first thing you take off the old door is the last thing you put on the new one. Take notes so you know which order stuff goes in Smile
plugger147
PostPosted: 14:03 - 18 Sep 2009    Post subject: Reply with quote
I can't remember if they bolt on or are held on with pins, have a look and if it is pins start giving them a squirt with wd40 a few days in advance.
Tristan the wrote: just whipped off my trousers to find a big bruise on my arse, caused by matt rear ending me...
tutton
PostPosted: 15:05 - 18 Sep 2009    Post subject: Reply with quote
Pretty simple as it goes, hardest bit as has been said is fitting the glass, butter fingers Laughing
Skudd
PostPosted: 15:15 - 18 Sep 2009    Post subject: Reply with quote
Best not to put butter on the fingers, unless your other half likes it that way.
Phoenix
Twisted Firestarter
PostPosted: 17:25 - 18 Sep 2009    Post subject: Reply with quote
Even if you forget where bits go you can just take the doorcard off the other side and compare it to that. Given it's a metro it's probably the most simple door going, manual window winder, no central locking or mirror electrics etc. Couple of hours work probably.
andyscooter
PostPosted: 20:09 - 18 Sep 2009    Post subject: Reply with quote
didnt the new door come with it fitted
extra tenner would of and the key for the passenger side lock Laughing
an id of waited to primer spray it untill fitted
The last post was made 17 years, 31 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.56 - MySQL Queries: 14 - Page Size: 57.39 Kb
