| catceefer |
 catceefer L Plate Warrior
| Alexio |
 Alexio World Chat Champion
| stinkwheel |
 Posted: 10:06 - 24 Sep 2009 Post subject: |
They are adequate on a CG125.
They will be an order of magnitude better than any BSA single leading or conical hub efforts. I presume you're after them for a bantam or a unit single of some sort?
EDIT: If you can make cables, make one up with car handbrake grade cable. You need to drill out the nipple to get it to fit but it makes a huge difference if half your effort isn't going into stretching the cable ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| catceefer |
| stinkwheel |
 Posted: 10:29 - 24 Sep 2009 Post subject: |
A CG is probably comparable to a C15 in terms of performance. Maybe slightly higher top speed on the Starfire.
As I recall, the starfire has one of those sort of one-sided, rim mounted drums so the CG one will be bigger anyway. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| catceefer |
| Nipedley |
 Nipedley Scooby Slapper
 Posted: 12:39 - 24 Sep 2009 Post subject: |
I have no idea how you'd go about it, but the CG weighs about 250 pounds so it should be effective enough for your bike  |
The last post was made 16 years, 171 days ago. Instead of replying here, would creating a new thread be more useful? |
