My 91 CR125 Street Supermoto Bike Build, on going..
TrevSkee
PostPosted: 18:03 - 29 Sep 2009    Post subject: My 91 CR125 Street Supermoto Bike Build, on going.. Reply with quote
Well well, new here fella's & woman.. Wink
Thought i shall show off what i got because its trapped in my back garden & i keep poking it with new parts once in a while Neutral
Well bought this a non runner for £400 Thumbs Down mid feb this year, needing new piston n ring & a power valve cover, i wish that was all that it needed doing but always turns out to be a mega on going money grabbing £ucking project! Surprised haha so i knew i was going to build something super with it as i do with everything i buy.. its personalization!
I rebuilt the topend myself (was easy as playing with lego) i sourced a topend with recent recon & bought new small end bearing, piston & ring & full gasket set, fitted all that & it started & runned fairly well for first time. Then the project began...
little clip of it then i got it going.. exhaust didnt fit header properly & rear pipe needed repacking why it sounds pop'ish, i sold the rear pipe & bought a 93 one
https://www.youtube.com/watch?v=9PL763QJBX0
As the pixs go from old (muddy) to how it is now (with both supermoto wheels on) i've spent abit over £1100 including buying it.. not bad huh?? Neutral
https://img.photobucket.com/albums/v363/trevcannon/My%2091%20CR125%20Street%20Supermoto%20Project%20Build/Photo0252.jpg
https://img.photobucket.com/albums/v363/trevcannon/My%2091%20CR125%20Street%20Supermoto%20Project%20Build/Photo0260.jpg
https://img.photobucket.com/albums/v363/trevcannon/My%2091%20CR125%20Street%20Supermoto%20Project%20Build/Photo0303.jpg
https://img.photobucket.com/albums/v363/trevcannon/My%2091%20CR125%20Street%20Supermoto%20Project%20Build/Photo0332.jpg
https://img.photobucket.com/albums/v363/trevcannon/My%2091%20CR125%20Street%20Supermoto%20Project%20Build/DSC_0005.jpg
https://img.photobucket.com/albums/v363/trevcannon/My%2091%20CR125%20Street%20Supermoto%20Project%20Build/DSC_0016.jpg
https://img.photobucket.com/albums/v363/trevcannon/My%2091%20CR125%20Street%20Supermoto%20Project%20Build/DSC_0039.jpg
https://img.photobucket.com/albums/v363/trevcannon/My%2091%20CR125%20Street%20Supermoto%20Project%20Build/DSC_0144.jpg
How it is now..
https://img.photobucket.com/albums/v363/trevcannon/My%2091%20CR125%20Street%20Supermoto%20Project%20Build/DSC_0149.jpg
https://img.photobucket.com/albums/v363/trevcannon/My%2091%20CR125%20Street%20Supermoto%20Project%20Build/DSC_0148.jpg
https://img.photobucket.com/albums/v363/trevcannon/My%2091%20CR125%20Street%20Supermoto%20Project%20Build/DSC_0150.jpg
Still not finshed it needs quite afew more little bits doing & forks seals need doing, the front supermoto wheel on it im getting the rim built onto the cr hub, renthal r3 chain, brake pads all around, gear lever, air filter, front exhaust.. i might get a cr500 one & mod the header to fit, then sorting out my diy electrics for my horn & speedo which i am going to use two 6v rechargeable hump packs you will find being used in model R/C kitcars
christ i do go on alot & i've hardly said anything about the bike just dont want to list everythink i have done to this bike! Shocked
ballbag
PostPosted: 09:20 - 30 Sep 2009    Post subject: Reply with quote
Looks good, really good. Old school.
I doubt very much that the CR500 front pipe will do you any good tho. The shape and size of 2 stroke exhausts (front pipe) makes a massive difference to their performance, and their CC, porting etc makes a difference to what kind of size/shape pipe you want.
Basically I would imagine if you put a CR500 front pipe on your 125cc engine it would run like a bag of shite. Get an FMF 125 power pipe for your bike and it'll rip.
Now get a video up of you pulling a wheelie! Very Happy
Progression
PostPosted: 10:26 - 30 Sep 2009    Post subject: Reply with quote
Looks really good. You did a decent job of the transformation. Still reckon it would look better now if it was muddy Laughing
Prog
Gazdaman
I did a trackday!!!
PostPosted: 19:27 - 30 Sep 2009    Post subject: Reply with quote
Lovely bike, powdercoat that frame white and you're onto a winner.
Gaz
PostPosted: 23:30 - 30 Sep 2009    Post subject: Reply with quote
Nice project, but as has been said, leave the CR500 expansion chamber for a CR500.
TrevSkee
PostPosted: 12:19 - 01 Oct 2009    Post subject: Reply with quote
Arrr think i'l be leaving the cr500 exhaust then, i only wanted it for how it looks fitted on the bike, what about a 250 one?? Laughing
Now the engine is bugger & bike nearly stripped i might aswell do the frame as i was guna leave that last. I now need to rebuild the bottom end aswell as the top skim head new piston & ring etc, its turnt into a full rebuild now, i would like to take on the rebuild myself as i done the topend just to get it running, but i dont know if i need new crankshaft? or to fit the bigend bearing myself?
If i did fit the new bigend bearing & rod, could i take it to a bike shop to get balanced etc then bring it back & fit it myself?
Gazdaman
I did a trackday!!!
PostPosted: 17:10 - 01 Oct 2009    Post subject: Reply with quote
Just whip the crank out, take it to a bike shop and ask them to swap the big end and con-rod over because it'll need a press.
Then take the crank back home and put it all back together. Simples.
And with regards to different exhausts, a 2 stroke works by using pressure waves to keep the mixture in the cylinder. So the exhaust (for best power) is very closely matched to the engine.
Use an exhaust meant for a different capacity and/or different bike/design/borexstroke and it'll run like shit.
You'll lose power and fuel economy.
So just stick with the correct exhaust, or an aftermarket one designed for your bike.
Gaz
Fnatic
PostPosted: 07:22 - 02 Oct 2009    Post subject: Reply with quote
As far as I am aware the expansion chamber on a 2 stroke exhaust use some very complex mathematics. I tried understanding it all once and failed.
TrevSkee
PostPosted: 12:52 - 02 Oct 2009    Post subject: Reply with quote
Gaz
Lovely jubbey Thumbs Up i shall be popping to my local soon & mean time saving up some money for piston and ring, bearings, seals and gasket set then tear down the engine for a winter build hopefully.
Haha i dont do any techy knowledge stuff myself, so i'l just throw a aftermarket one & be done with it. Very Happy
My 1991 CR125 Street Supermoto Spec'd Project Build
STOP clicking that link ^ and wait for me to do a UPDATED post.. Wink
Gazdaman
I did a trackday!!!
PostPosted: 22:46 - 02 Oct 2009    Post subject: Reply with quote
Read a book called 2 stroke tuning, by Graham File.
I managed almost 3 pages before wanting to kill myself and everyone around me.
Gaz
smegballs
PostPosted: 13:23 - 10 Oct 2009    Post subject: Reply with quote
Ever read the four stroke tuning one.....
Its even worse. Rolling Eyes
Basically he says "dont think about it unless you have a full gas flow rig to work with"....
Now who wants to hear that...
TrevSkee
PostPosted: 18:40 - 08 Dec 2009    Post subject: Reply with quote
Well well sorry no updates if anyone is interested! Laughing
Money flow at this time of year & xmas comming up makes it shy, but still collecting parts i need to rebuild the engine & tools to take it apart properly only last tool i need is a bearing extractor then i can buy the rest of the parts i need, piston, rod & full gasket set etc
Last bit i bought for it was 2-3 weeks ago & was a gear lever, a nice red tip rfx hardware one for £15.00 Rolling Eyes
A mate of mine has a bike nut mate who i was guna borrow 4 stroke book havnt heard anything back yet & the 2 stroke one i saw one on ebay but forgot to bid on it Brick Wall i only want to experience the head fcuk headache of it..
stevo as b4
PostPosted: 22:48 - 08 Dec 2009    Post subject: Reply with quote
What is it about the 250cc and 500cc expansion chambers that looks better exactly? Apart from being a longer fatter snake than the 125's, i can't see what looks different/better about them?
TBH all the std black double skinned pipes, with nasty looking brackets and heat sheilds added with great big gobs of japanese at it's best welding, looks pants IMO!
A nice rolled cone style aftermarket pipe either clear coated or nickleplated is far more sexy!
TrevSkee
PostPosted: 23:07 - 08 Dec 2009    Post subject: Reply with quote
"personally" to me they look better, how they are to 125 or 250 ones, like for exp.. i bought £220 levers just because i liked them more than these other £40 set they do the same thing but mine look better to me Wink
That idea is well truly binned anyway just when i can find one & can afford it at the time it will be within my part collection
PostPosted: 14:10 - 09 Dec 2009    Post subject: Reply with quote
I thought I was a prick spending £85 on second hand lever for my new 600 Laughing
Money may have been better spent on a
https://www.demonmx.co.uk/contents/media/l_cr125large.jpg
https://www.demonmx.co.uk/contents/en-uk/d415.html
ballbag
PostPosted: 14:03 - 10 Dec 2009    Post subject: Reply with quote
I've very interested. I love these sorts of projects. Hurry up.
TrevSkee
PostPosted: 18:32 - 11 Dec 2009    Post subject: Reply with quote
I havent used demon mx for ages im sure they didnt have these listed on the site, but still thats £10 cheaper anywhere else i've seen them, cheers Thumbs Up
mmm.. im in two minds a dep because i like the bare finsh look or fmf chrome to match the wheels etc
ballbag wrote:
Hurry up.
I AM LOOK..
https://img.photobucket.com/albums/v363/trevcannon/My%2091%20CR125%20Street%20Supermoto%20Project%20Build/DSC_0152.jpg
i actually took that about 2 months ago & still exactly the same today Embarassed
PostPosted: 19:16 - 11 Dec 2009    Post subject: Reply with quote
You really need to paint the frame, take everything off of it and get it powder coated it will be worth it. Thumbs Up
MugenSeiki
PostPosted: 19:19 - 11 Dec 2009    Post subject: Reply with quote
this
Looking good man but what's up with your camera ? 70's porno quality look FTW
www.dt125.co.uk
Gazdaman
I did a trackday!!!
PostPosted: 19:43 - 11 Dec 2009    Post subject: Reply with quote
Thumbs Up +1
Gaz
The last post was made 16 years, 323 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 2.15 - MySQL Queries: 13 - Page Size: 119.42 Kb
